Railroad Line Forums - Harmony Junction Switching Layout
[ Active Members: 6 | Anonymous Members: 0 | Guests: 239 ]  [ Total: 245 ]  [ Newest Member: Uncle Pancakes ]
Author Previous Topic: SL&N construction blog Topic Next Topic: Chuck Diljaks Wyoming Valley Railroad
Page: of 16
Posted - 07/29/2020 :  2:17:46 PM  Show Profile  Reply with Quote
Good point, James. I'll take a look at that.
Fly Army
Country: USA | Posts: 16795 Go to Top of Page
Posted - 07/29/2020 :  6:28:14 PM  Show Profile  Visit Bernd's Homepage  Reply with Quote
Interesting way to attach ties. Filed for use on the HOn30 quarry line.
Country: USA | Posts: 3953 Go to Top of Page
BurleyJim
Posted - 07/29/2020 :  6:53:10 PM  Show Profile  Reply with Quote
Looks good, calibrated eyeballs are working very well. Hope the Barge cement works better than the Pliobond I tried over here.
Country: USA | Posts: 6178 Go to Top of Page
Posted - 07/29/2020 :  7:14:10 PM  Show Profile  Reply with Quote
George, it looks great even though it's unfinished!
Country: USA | Posts: 4154 Go to Top of Page
Posted - 07/29/2020 :  7:31:45 PM  Show Profile  Reply with Quote
Bernd, I used this technique on the club layout about 15 years ago on guard rails on a bridge. The bridge had an arc, transitioning from a grade to level, so the rails are under stress to pop up and become straight. So far it's holding. I used Pliobond for that.
Jim, Thanks. I read somewhere that Barge Cement is better, so I used it.
Thanks, Carl. A Looong way from being finished.
Georgr
Fly Army
Posted - 07/30/2020 :  08:54:45 AM  Show Profile  Visit Frank Palmer's Homepage  Reply with Quote
George, your meticulous construction methods are paying off. The trackwork looks beautiful.
Country: USA | Posts: 6133 Go to Top of Page
Posted - 07/30/2020 :  10:24:30 AM  Show Profile  Reply with Quote
Thanks, Frank.
Fly Army
Posted - 07/30/2020 :  9:23:03 PM  Show Profile  Reply with Quote
I've taken a minor detour. James van Bokkelen (jvbv) suggested that both the wood ties and the PCB ties should support the rails. The PCB ties are 0.037 high and the wood ties are 0.080 high. A rather obvious observation, which I completely overlooked. I figure a piece of 0.040" styrene and the glue will fill the space nicely.
This gave me an opportunity to use my Cricut cutter for this project, I made a set of drawings for the shims which are the same size as the PCB ties, loaded them into the Cricut and cut them from a sheet of 0.040 styrene.
Cricut doesn't cut all the way through 0.040 styrene. I had the machine scribe all the cut lines and then I used the standard styrene scribe and cut procedure to do the task. The advantage of the Cricut is that it scribed a sheet in about 10 minutes and it was extremely accurate. A few years ago I bought a hand seamer from Harbor Freight. I wanted something for snapping long small pieces of styrene. This was the perfect tool for this job. By the way, if you are thinking about buying one, take a good look at their stock, not all the jaws line up properly. Pick one that looks good.
I made two sets of ties (two different cuts). One of standard length ties and one of long strips that could be cut to length for the many turnout tie lengths.
Now to start gluing them to the bottom of the PCB ties.
Fly Army
Posted - 07/31/2020 :  08:00:28 AM  Show Profile  Visit jbvb's Homepage  Reply with Quote
One other thing about contact cement holding rail to ties: If the layout is subject to temperature swings, you might want to come back to it after it's running well and back the glue up with spikes every 8th or 12th tie. My experience has been that as rail shifts, it will eventually start to break the glue bond, particularly at high temperatures.
Edited by - jbvb on 07/31/2020 08:01:45 AM
Country: USA | Posts: 6809 Go to Top of Page
Posted - 07/31/2020 :  09:09:52 AM  Show Profile  Reply with Quote
James, I'll be keeping a close eye on it. I'm familiar with rail expansion from experiences at the train club. I'm planning to cut a gap in one of the rails to allow for expansion once it's all fastened down.
Fly Army
Posted - 07/31/2020 :  09:32:41 AM  Show Profile  Visit wvrr's Homepage  Reply with Quote
Interesting tool, George. And a nice solution. I will have to keep this tool in mind the next time I visit Harbor Freight.
Country: | Posts: 6658 Go to Top of Page
Posted - 07/31/2020 :  11:58:43 AM  Show Profile  Reply with Quote
Thanks, Rick. It's a handy tool that I've used on several styrene projects.
Fly Army
Posted - 08/14/2020 :  09:54:57 AM  Show Profile  Reply with Quote
It's been a while since I've posted an update. I've glued all the styrene shims under the PCB ties. I then cut up a 1/8 sheet of cork for the roadbed and fastened it down with DAP adhesive.
I used the same adhesive to fasten the track to the cork roadbed. I've given the track a little nudge and it's very secure.
The adhesive takes paint, so all that white will disappear.
When I applied Barge Cement to the bottom side of the rails to hold the wood ties, I didn't apply it to the stock rails adjacent to the moving point rails. I didn't want to take the chance of any glue getting on the point rails when it was heated. My next step is to cut and glue wooden ties in these gaps. I'll be gluing them to the cork, not the rails.
Fly Army
quarryman
Posted - 08/15/2020 :  05:40:43 AM  Show Profile  Visit quarryman's Homepage  Reply with Quote
George-
I was thinking that you would spike the rail down to the wooden ties. Then you could go around and unsolder the PCB ties from the rail, pushing each one down and sliding it out, then slide a wooden tie in to replace it and spike it in place. What you came up with is new to me. I guess I never considered glueing track down because my layout is in an outbuilding. Not only temperature but also humidity rise and fall over the course of the year, affecting both the rail and the roadbed.
Thanks for posting the updates,
Mark Chase
Richmond VA
Country: USA | Posts: 1207 Go to Top of Page
Posted - 08/15/2020 :  08:02:20 AM  Show Profile  Reply with Quote
Mark, I've read about using the adhesive in several places. It has a slight flexibility, I don't know if it's enough for the large swings in temperature you're dealing with.
Fly Army
Page: of 16 Previous Topic: SL&N construction blog Topic Next Topic: Chuck Diljaks Wyoming Valley Railroad
Steam was generated in 0.67 seconds. Powered By: Snitz Forums 2000
