[ Active Members: 4 | Anonymous Members: 0 | Guests: 39 ]  [ Total: 43 ]  [ Newest Member: Faire to Midland ]
 On3o layout
Stumps63 Posted - 02/03/2019 : 3:10:38 PM
Hello,new to On30 would like to build a layout in a 12x16 area.It would be around the room with continuos operation.Coming from ho wondering if this space would be sufficient in O scale
Thanks
10   L A T E S T    R E P L I E S    (Newest First)
Stumps63 Posted - 02/05/2019 : 6:33:50 PM
Well thanks Dave.I had a older brother who went by stumps.He was big into C&S mainly in Sn3. He passrd a few years back so I guess its sentimental.
David Clark Posted - 02/05/2019 : 2:45:06 PM
Stumps (you have a real name?),
Welcome to the best source for information and assistance anywhere. The members here are avid and knowledgeable. Check out Rob Chant's thread on designing layouts. He loves to doodle and has great ideas. It is sometimes hard to find info on the site but if you use Advanced Google Search and restrict your search to the "railroad-line.com" it will search this site better than the internal search engine. Louis had more schematics and data than the library of Congress.
I look forward to watching your build.
ChiloquinRuss Posted - 02/04/2019 : 10:14:52 AM
Biggest difference as far as I'm concerned comparing HO to ON30 is the structures. What looks good in HO takes lots of structures, that same scene looks good in O scale with a few detailed structures. IE running steamers in HO and making even a small engine terminal takes many buildings while a small engine terminal in O scale can be very effective with just a few structures. That's my 2 cents worth, spend wisely! Welcome to the dark side, you'll love it! Russ
Stumps63 Posted - 02/04/2019 : 12:15:12 AM
Thank you all for the great info.I thought I was going to have to go with a smaller scale.Glaf I waited and looked for advice
desertdrover Posted - 02/03/2019 : 10:56:54 PM
Originally posted by Stumps63
The biggest locomotive will be a Broadway Limited C-16 the rest Bachmann 2-6-0 mogul so I'm thinking a 22 inch radius
Try to go no less than a 22" for best performance. See here for some good informational help; On30 Commercial Loco and Car Minimum Radius Guide - http://www.npcrr.net/On30/On30Loco_n_Car_Radius_pics.pdf
Stumps63 Posted - 02/03/2019 : 10:13:28 PM
brucet Posted - 02/03/2019 : 7:36:57 PM
I have a 2' x 20' layout with a loop at one end. My biggest suggestion is to look very very hard at your minimum radius. That radius will determine a lot of what you can do. I have one curve that drops down to 18 inches. That short 18 inch section gives me most of my headaches. Think very carefully about what you want to run and test test test and test again to see if your preferred locos will run on your minimum radius.
And have fun. Fun is the key.
bruce
BigLars Posted - 02/03/2019 : 5:26:41 PM
12x16 is a larger space than most ON30 layouts live in. I hope we are all following your build soon.
Stumps63 Posted - 02/03/2019 : 4:16:42 PM
Thanks that really helps.
desertdrover Posted - 02/03/2019 : 3:30:35 PM
You can do a lot within that size of an On30 layout. Here is just one example of an outstanding layout, the Thunder Mesa Mining Co. On30 Overall size: 15.5'x 8.5' http://thundermesa.studio/model-railroads/track-plans/
There are many plans within your measurements for great looking On30.
Steam was generated in 0.16 seconds. Powered By: Snitz Forums 2000
