Nice job, Larry. I like the beefy posts; they seem about right for a structure of this type. Also the size of strip wood for the sheathing looks good. For a different look on future buildings like this, you could use 8x8 or 6x6 diagonal braces to look like they've been mortised and tenoned into posts and beams. But I think for a shed like this what you did looks good and is appropriate.
Philip thank you. Well since we've had a few days of rain the outside projects have halted
now and then. Gave me a chance to work on the diorama, so here is an update:
Before I could go much further with the building I needed to get the rafters built and the lighting sorted out. The rafters
were constructed from 6x6's using a pattern that I drew up on graph paper. Actually they all came out pretty much the
same. You'll notice that not all the rafters are colored; figured I'd only color what would show to save on materials.
In order to have a light in the shed portion of the building I needed to redesign that part a little by adding one rafter over
the workbench which changed the look somewhat but that only made it look unique. After shortening the 10 light set to 3
I ran the wired through each rafter with the lights glued to three of the rafters. After this was done then I glued each rafter in
place one by one. It ain't pretty but it works well. The wire comes out the bottom of the building and a trench will be dug in
the foam to hide it leaving the power pack at the back off of the display. Everything runs on two 1.5 AA's with an on and off switch.
The actual lights are LED's.
Here is the shed area all lit up even though you can't see the light from the front. This is all done with one light.
The garage part of the building uses two bulbs which lights it up quite nicely. Even though this is my first attempt at adding lights
to a building I'm rather pleased with the look.
Next up is working in the sub roof and the actual roof itself, I'm leaning towards a wood shingled roof for this project which should
fit in quite nicely with the overall theme of the building.
That's about it for now and thanks for looking.
Jerry and Rick thank you. Thanks for the suggestion Rick, I agree the warmer light would look better.
I didn't even think of that but it's an easy fix.
Hey Larry, I heard some hammering going on, and I had to get on over here to see what the fuss was all about.
This build of yours is one that I have been wanting to construct myself, and I have been watching closely. I too,
have been fond of the models that Brian Nolan constructed, and this build of yours is no exception. Your
attention to the fine details will put this diorama over the top when you add more to it later on. It will become
a focal point on your layout and I would consider it be placed in the forefront somewhere, if it were me.
I would like to mention that strand of lights you are using, as I use them myself. One nice thing about them is
you can cut off as many as you want, and they still work. I read that you are going to put the battery case at the
back of the display board. That is a good spot, but as an alternative solution, you could place the case underneath
any small shed as well. (without gluing down the shed to the diorama) so you can change the batteries, and the
unit won't be seen. Just as a reminder, don't leave the batteries in the case for an extended time if not using them,
they will corrode and the acid will destroy the metal.
Sorry this is lengthy, but I will be following along more closely now. You are an excellent builder.
Michael thanks. Adding lights is something that I've been wanting to do for awhile so this gave me
the chance to do so.
Mike thank you. I've already painted the lights and it does give it a nicer look. I'll post a photo soon.
Rich thank you for the kind comments and for stopping by. I'm using Brians repair shed as an inspiration
only and will add my own twist to it. I do like your idea of hiding the battery pack better. I may add a small shed to
the back area so that could hide the batteries. Usually I remove the batteries when not in use; had too many
issues with them over the years. It nice to hear someone else uses the same lighting so I guess I wasn't too far off.
I also have a couple of other ideas of hiding the battery pack that I have used in other builds.
If you saw where I built South River Model Works - Martin's Machine Co. scratchbuild, I made a slider door at the rear of my diorama. Inside that slider door is where I positioned the battery pack - out of view. In that build, it could only be accomplished due to having a large, inside space with which to mount the pack. (First picture)
On anorher build, I made a drop box to house the battery pack, below the diorama. That was my build of the Kitbashed Yorke kit- Critter Engine House in HO, which can be found here: https://railroad-line.com/node/37296/page7 (Second picture)
Perhaps there are alternative methods but these did work for me. Just trying to give you a couple of ideas here. I'm confident you will find a solution that will work for you.
Good luck,
Rich thanks for the suggestions. Looking at your first photo; that is a very nice looking building and I'll have
to read through your "York" thread when I get a chance. It's always nice to see how others handle the same
things that I'm working on.
Using Rick's suggestion, the light bulbs were give a couple coats of yellow-orange paint. The color looks more natural
for that era. That what's so great about this forum is the sharing of ideas and techniques.
Still working on the roof of the Repair Shed coloring, weathering, cutting, and glueing as I go along. I guess that's it for the
time being and thanks for looking.
