Walthers Mainline F40PH Problem
  • Walthers Mainline F40PH Problem
    I need some help. I just purchased two Walther's Mainline Amtrak F40PH locos. The snow plows on them are catching on any joint that is not snug. If there is any gap the plow is catching on the gap. One of the plows actually broke off. I am using Atlas code 100 track.
    I have never experienced this problem before. No other loco I have has this problem.
    Upon closer inspection it appears the plows are basically riding on top of the rails. There is no clearance between the plow and the rail tops. Has anyone else have this problem? Any suggestions?
    I am trying to see if I can find any photos of the locos without the plows.
    My suggestion is they look too low from the factory anyway. I'd re-drill the mounting holes or shave of the bottom front a bit. You could always get another from any detail manufacture. Just my 2 cents worth. The photos below show what the plow should look like. So I'd file away at the bottom of your plow and call it a day.
    • k9wrangler
      k9wrangler commented
      Editing a comment
      I’ll have to “file” that suggestion away for future use ;-)
    And your suggestion Karl is??????
    • k9wrangler
      Editing a comment
      My suggestion is Listen to LOU!
      Better yet, I’ll butt out.;-(
    Another thing to consider is how does the rear door and buffer/walkway line up with your passenger cars? If they're pretty much even, then I agree with Lou: file the bottom of the plow.
    But if the F-40's body rides low compared to the passenger car's diaphragm or end door, then you might look at placing shims between the F-40's truck bolsters and its body. In the old day, shims there would need to be metal, like the Nickel Silver sheet available from Clover House, to ensure that power reached the motor. But many modern locomotives have power feed wires from both rails on each truck. In this case the shims could be plastic.
      I got an answer to my email to Walthers. File the plows which I did and it appears to solve the problem. I know it is an easy solution and took only about 5 minutes but I don't appreciate having to do a modification to a brand new loco fresh out of the box so that it can run properly.
      • desertdrover
        desertdrover commented
        Editing a comment
        Well that I agree on with you Tom, but seems now-a-days that's how things are done. No quality control anymore.
      Now Karl, no-one is suggesting you butt out. I was genuinely asking what your take, or suggestion would be on this if it were you.
