Thanks Guys for all your comments, and thoughts. Kirby & Dyson it is. I like that!
Lou’s RR Track Vacuum Car
In the previous pictures posted, I showed the Felt Pads I’ll be using for this project. Scotch Self-Stick Floor Care Pads. With a ½” hole punch I cut out two discs for the Track Cleaner. Next with a surgical blade I flayed the felt pad down about a third of its thickness. Now, I’ll be able to run two Roundhouse cleaning disc pads in the front, and two felt disc pads in the rear. This way with each pass over the tracks, I’ll get a cleaning, then a vacuum, finished with a felt buffing.
The third picture shows a view of the underside, showing the cleaning and buffing pads, as well as the vacuum chute nozzle.
The next set of pictures shows the view from the left side, and right side, of the Boxcab Vacuum with Kirby and Dyson at the controls.
The last picture shows the rest of the crew ready to be mounted in place on the Vacuum MOW Machine assisting Kirby & Dyson.
- 1 like
Great job Louis. Now you'll need to add a vacuum cleaner sound. Can't wait to see it run down the tracks.
BerndNew York, Vermont & Northern Rwy. - Route of the Black Diamonds
Originally posted by Larryc View PostLouis that is an outstanding job!!!! Hope it works as well as it's designed.
Originally posted by Bernd View PostGreat job Louis. Now you'll need to add a vacuum cleaner sound. Can't wait to see it run down the tracks.
Originally posted by Michael_Hohn View PostThat seems like a large crew. They must be having a joy ride.
Most of its life it will be in a yard anyway, so it will appear as work being performed.
- 1 like
I wanna see it run and I wanna see it right now !
How about sprinkling a little "trash" on a test track with a before and after photo ?
Nice work my friend. I expected nothing less.
Just thinking out loud (not thats scary) Name on side of car............Electrolux-1GULF COAST & WESTERN
Hi John, thanks for your comments and thoughts. I don't need to put trash down for a test run, I've got years of dust and dirt down already. I've got an unfinished ceiling in the basement, (Something I should of done years ago) so I get all the occasional crap from the floor and joists above.
Well, we’ve come to the end of the line with this project. Sorry, I know it may be boring, but I went with naming it the “L&R Vacuum MOW” with a Road #33.
I did go with Kirby & Dyson for the crew operators. I have enjoyed this project for many reasons, but the most enjoyable reason is that it actually works. If it didn’t, you would have been reading a lot of nasty words by now.
A few finished pictures of my project, and for those that like to see some kind of Prototype, I post the last picture of the Worlds Largest Vacuum Cleaner for the rails.
- 1 like
Louis,
Interesting model and prototype both. Your track cleaner looks terrific even though it would score few points for “conformance” in an NMRA contest.
I learned a lot in watching you build. The result is very cool.
Well done, Louis.
Has OSHA checked that Kirby and Dyson are properly protected from the dust?
George"Aviation in itself is not inherently dangerous. But to an even greater degree than the sea, it is terribly unforgiving of any carelessness, incapacity or neglect." Captain A. G. Lamplugh
