MTH H8 2-6-6-6 Allegheny
  • MTH H8 2-6-6-6 Allegheny
    Hi -- I posted this in the "Roundhouse" forum but maybe it is more relevant here. Has anyone managed to remove the boiler from the frame on a MTH H8 2-6-6-6? I have it loose after removing 2 hidden screws on the top; But it only partially lifts at the back and it is hung up near the front. It looks like I need to either remove the front plate or some piping to get enough clearance around the right running board. Could not find anything useful at MTH or posted elsewhere online. Sure could use some help. -- Thanks -- Bob
    Is yours an HO or O gauge? And do you have a screw in the rear like this?
      Louis -- Thanks for the reply. Mine is HO and does not have that screw but I just did this am get the shell off. A portion of the left ladder behind the shell under the cab needed to be bent flush with the shell so that the ladder could just slip past the frame. Once separated at the back I could maneuver it enough to break free at the front. Now to see what it will take to replace the smoke unit with a speaker and replace the decoder
      Thanks again for the response. -- BobR.
