Ron nice job on the tractor. And really like the color on the steam engine. After weathering a little they should fit the bill perfectly.
Completing the Lyon Tractor & Railcar Works
OK, time for an update.....
Finally finished the tractors. First up is the Bates tractor that is in the shop getting a track repair done.
Only a little rush has been added as it is a "well" maintained tractor that is still earning it's keep.
Next up is the cat, lets just say it has issues.
As you can see the cat has been neglected. It is sitting in the yard gathering rust as the engine has some serious issues and the owner of the Cat decided not to fix it as the cost was too rich for his blood. According to Mr. Lyon you can have it real cheap if you want it. The only thing the Cat is doing now is gathering dust and growing rust.
http://cvry.ca
- 1 like
Ron great job on the tractor weathering and love the mud on the tracks and drive wheels.
Yup Rick's right...what's wrong with us when crud, rust, and crap looks good.Owner, General Manager, and all around "chief cook and bottle washer" of the Caz Coal-and-Wood Railroad
Thanks for the comments Larry, Roland and Scott, they are much appreciated.
Some progress on the power components required to drive the line shaft.
I figured out that in order to easily build, weather and scenic the steam engine, boiler and water tank, it would be easier to build them on there own base. The base is .o1o styrene so should be easy to blend it in to the diorama. Shown here are the relative position of the components.
This will give an idea of where the items go at the back of the building.
http://cvry.ca
- 3 likes
