On30 Shadow Box design layout
  • On30 Shadow Box design layout
    Want to build a shadow box layout....want to build a six foot section First and start with that.....and see were it takes Me. Anyone build one ? Want to use Wood in the build. Looking for info. Thanks
    Were we go one We go All
    I don't recall seeing any Craig.
      Craig, Will be nice to seeing you modelling again.
      Over in the Micro / Mini layout Forum, forum member Kumard, did stunning work in HO scale. Did several shadow box layouts, that stacked. Some of the best scenery I've seen.
      https://railroad-line.com/node/33502
      https://railroad-line.com/node/34446
        Kumard's Depot layout.
        Click image for larger version  Name:	2016103182558_Kumar Display Case 1.jpg Views:	0 Size:	54.6 KB ID:	968627
          Thanks Rob for posting that info, but its not my cup of tea Theres 2 guys that did a nice On30 Shadow box layout I liked on MRH.... but you cant pm anybody 0n the form at this time?? I would like to see myself modeling AGAIN TO
            Rob, I liked the last picture you posted.
              I think I found what I'm looking for on another Forum?
                Hello Craig. Are you going to include any links, so we can see what you have in mind.
                Some more ideas
                https://smallurbanrails.wordpress.com/tag/shadow-box-2/
                https://model-railroad-hobbyist.com/node/21914
                  And Geoff Nott always did stunning work, quiet often in shadow boxes. Quiet often just a loop
                  Lily flat
                  http://www.modvid.com.au/html/body_g...lily_flat.html
                  Moose Town
                  http://www.modvid.com.au/html/body_g...oose_town.html
                    I like shadow box layouts or dioramas. I like the way they direct the focus on the modeled area as opposed to having outside influence from pipes, joists, and water heaters, etc.
                    I will be following.
                    Russ
                      Rob, I would do some link's but I have NO IDEA how to do it and never did it in all the years owning a Computer???? I would have to pay a computer guy to show me.
                        Copy and paste the address from the page you are trying to link to into your message and the forum software should be able to do the rest itself
                        Plywood should do well for the arch over the front of the layout but lighting has to be fairly carefully thought out. The photo that Rob posted above shows what can happen: because the lighting is behind the arch it is shining straight down at the front of the layout and casts dark shows on the sides facing the viewer of any structures close to the edge of the layout. Lighting a bit closer to the viewer than the edge of the layout sorts out that problem
                          Craig. have the forum open and be signed in in one tab of Google. Then open another tab and find the page that you need to to link to. MRH site I think you mentioned.
                          Highlight and copy the link address (URL)
                          then go to this thread in RRL forum.
                          Click on the link icon ( in yellow)
                          Then click on the URL box, right mouse click, select Paste. Then click OK.
                          The link will now appear in your post. Click post reply.
                          Hope this helps. You don't need a computer expert. Help is here, or ask a friend or neighbour.
                            I dont know? Ill try to mess with it a little have to make time for it and see what happens ??????
                              nothing to report...... bought 1 4x8 1/2 inch plywood for the shadow box..... havent cut any wood yet maybe next week
