My Version of J. Baum Tobacco Co. (FSM) 2 years and 2 layouts
  • My Version of J. Baum Tobacco Co. (FSM) 2 years and 2 layouts
    I started this back in 2019. I have always liked the look of of J. Baum Tobacco Co. with it's brick lower section with a overhanging wooden upper floor. I needed A lot of back ground buildings along the back of the upper level. I figured I could make it into one of those buildings. This is what I came up with.
    Click image for larger version  Name:	Building 1.jpg Views:	0 Size:	137.6 KB ID:	967020
    I used a DPM wall section for the lower floors and Scratch built the upper floor. Here it is in place on the layout I didn't know at the time I had built in a problem. It turned out that it was top heavy. I came in one morning and it was laying across the tracks. In the fall a few details got knock off. I repaired the details and put it back in place with some lead weight added to the bottom and more double sided tape for a second try.
    Click image for larger version  Name:	Building 2 in place.jpg Views:	0 Size:	59.8 KB ID:	967021
    But alas this didn't work either. Living in an apartment I didn't want to glue it to the wall. I had enough room on the other side of the tracks for a small add on to the main building that would be accessed by a covered walkway from the third floor of the main building to the new building plus it would add a little character to the scene.
    Mike Mace
    Nice job on that "J. Baum" Mike.
    Which DPM kit does that wall come from?
      The next thing was to build the covered walkway. It had to cross two tracks and a dirt road. I used wood for the walkway and Evergreen Scale Models I and H strips for the steel parts. Here are some photo of the construction of the walkway.
Name:	Elevated walkway 1.jpg
ID:	967027Click image for larger version
Name:	Elevated walkway 3.jpg
      Here I'm testing where the walkway will go.
      Next I installed the siding to the walkway.
Name:	Applying siding.jpg
Name:	Siding finished.jpg
      Here are a couple of photos with the walkway installed to the main building.
      So this is how I solved the case of the falling down building. Next time I will show the third addition to J. Baum's.
      Thanks for looking.
      Mike Mace
        Carl thanks for the kind comment. I can't find which kit it came from I do know that it is from one of their very early runs before Walther took cover. I still have a bunch of their early stuff that I use for kitbashing.
        Mike Mace
          Mike, that's a great looking rendition of George's J.Baum Tobacco.
          Also a nifty solution with that added walkway to keep it from falling over.
          Look forward to seeing this third addition you speak of.
          Greg
            I'm with Greg. Good solution.
              Greg thanks for the nice comments. My history of J. Baum's figures that the two story brick building is where the original business was located. After a time they needed more space and only way was up. That would make the wooden third floor the first addition. When they needed even more space a small plot of land across the railroad tracks was the only option. The walkway also had to clear a small dirt road along the railroad for RR access making the area even smaller.
              Mike Mace
                George thanks for the kind comments.
                Mike Mace
                  Great looking structure Mike and well done. Fantastic ideas and well executed craftsmanship.
                    Mike M,
                    Excellent modeling. J. Baum sure has lots of character!
                    Mike H
                      Looks great Mike!
                        Very nice.
                        Paint and subtle weathering are particularly good.
                          Louis Thanks for the nice comments.
                          Mike Mace
                            Mike thanks. I had hoped to give it some more character.
                            Mike Mace
                              Philip Thanks for the nice comment.
                              Mike Mace
