O scale Maine Lobster Boat
  • O scale Maine Lobster Boat
    Hello, This is the third in my series of fishing boats, for my Maine waterfront diorama.
    Like the other two boats, I'm using a cheap laser cut kit as a starting point. $11 including delivery.
    Although the kit say 1:50 scale it's actually 1:66, S scale. It's the hull that I mainly want.
    Here's a recap from when I made the hull at the same time as the other boats.
    This is my inspiration
    Click image for larger version  Name:	lindsayD-067.jpg Views:	0 Size:	45.6 KB ID:	966218
    Click image for larger version  Name:	Ralph-Stanley-Downeast-Picnic-Lobster-Boat-Good-Boats-for-Sale-4.jpg Views:	0 Size:	76.1 KB ID:	966219
      here's the basic kit and how it assembled. For more info on full hull assembly look here: https://railroad-line.com/node/40230
      Click image for larger version  Name:	P1020490.JPG Views:	0 Size:	148.8 KB ID:	966221
      Click image for larger version  Name:	P1020494.JPG Views:	0 Size:	59.7 KB ID:	966222
      I fillef in the spaces with balsa blocks for rigidity, as this will be a waterline model. So the spine will be cut off
      Click image for larger version  Name:	P1020888.JPG Views:	0 Size:	128.7 KB ID:	966223
      Click image for larger version  Name:	P1020889.JPG Views:	0 Size:	94.8 KB ID:	966224
      Click image for larger version  Name:	P1020890.JPG Views:	0 Size:	41.8 KB ID:	966225
        Robert this looks like a very interesting project and your off to a great start. I'll have to check in
        and see how this is progressing. Keep up the good work.
          Robert I followed the last one so count me in on this one to. Its amazing what you do with a cheap kit great start on this one!
            Same here as Jerry said. Enjoyed your last thread build, so here for the following of your progress on this one, nice looking boat!
              Following!
                These are great builds, standing by for more Rob ...
                  Thanks Larry, Jerry, Louis, Phillip & Carl. Nice to be able to finally start a new thread, on the New Forum. My 403 errors have finally disappeared.
                    I started making up the cabin / wheelhouse.
                    Using the existing parts for sub walls, but have clad them in boards and have extended the height of the wheelhouse section to O scale.
                      I guess when it comes to changing the size of the scale, that the cabin/wheelhouse is what shows and makes the difference.
                        Rob nice job on the wheelhouse!! Really like the color and I assume it's going on your diorama
                        that you've been working on.
                          Thanks Louis. Yep, boat hulls can be any size, so scale not so important there, but the cabin has to be the right height.
                          Thanks Larry. yep, the colour is warm red, but because it's over a tan base, it gives a slight orange hue. Just what I was after. And yep, for the diorama. I just needed a break from that.
                            I've added a band of crimson colour to the hull, just to beak up the overall white.
                              And now working on the front deck.
                              It's raised up from the main deck, so have made a balsa frame under it.
                              And some supports for the sides
                              The deck is made from balsa sheet.
                              Can glue it in place now
