Question on Blogs
  • Question on Blogs
    I noticed that the blogs seems to only allow you to enter text. There is no banner menu like there is for the forum messages that allow links, pictures, different fonts, colors, etc. Just wondering if there's more that I'm not seeing or if that's the extent of blogs.
    just created a test blog.. looks like i can add a second entry with all the options of a post..
    learning this software with the rest of you !
    Joe
      looks like you have to choose blog entry vs reply...
        I'll try it out tomorrow. Thanks Joe.
          Morning Joe.
          Been playing around with the Blog post. I'm logged on with two desk tops so I can follow through with the Blog post. Not being successful. You stated "looks like you have to choose blog entry vs reply..." . Below is a screen capture of what I see.
          I only have two choices, "Create a New Blog or New Entries. Obviously I don't want to create a new blog entry and the New Entries would bring up blogs posted by other members to search. Since I'm the only one that is trying this out it tells me that there are no new entries. The only other choice I have is to "Post Comment" which doesn't have any provisions as the regular thread posts have on the forum sections. I can answer a quick question if somebody posts but can not post any pictures to continue on with the original name of the blog.
          I'm not asking you to jump on this subject matter ASAP. I'm sure you have more important problems to solve on the forum. I can wait until you get around to seeing what can be done if anything.
          Here's what I'm thinking at the way it should work. When you create a new blog and give it a name it should be the main subject name. Then as you add to your blog each update/added information should have a separate header explaining that post. At least that's what I've seen on Blog's I have visited.
          I want to thank you for work on getting this forum back up and running. It's my top forum to go to because of the guys I've gotten to be friends with over the years I've been on and as soon as you get that Donation Button I'll have a digital check in the mail.
