It's Plastruct styrene; luckily I actually had a pack on the shelf!
So, there's a skin of 0.010" styrene on the surface that the tank body will get mounted to using two of these ends. The corrugated styrene was added to the exterior flat side and then 0.060" square stock was bent around end block flush to the top of the corrugation. That leaves that skin of 0.010" styrene available for the side and that square stock gives the side something to butt up against. All of this was assembled using Goo and CA - Goo 1st, pull apart, add CA, clamp and weight and come back tomorrow. Actually had the ends in the big wood vise to hold the 0.060" square stock in place. Then I went back with a brush and welded it together more with solvent.
Now it's time to add the tank sheet to one of the ends; I expect this to be a slow & steady exercise and that the big wood vise will see use throughout.
