Rebuilding a Damaged HO scale Brass Overland Models Inc. C-430 Tank Drive
  • Rebuilding a Damaged HO scale Brass Overland Models Inc. C-430 Tank Drive
    Hi all,
    I can't stress enough when shipping a model, really good packing is always important and proper foam packing of hand rails and end pilots is part of it. The following pictorial is how I addressed this repair. I hope this gives an idea or answers a question or two on your model.
    Thanx Thom...
    Photo 1 Shows opening the box. Hummm? What have we here?
Name:	1 opening box.jpg
    Photo 2 I notice this model is not factory painted/lettered so no collector value is lost.
Name:	2 not factory painted lettered.jpg
    Photo 3 Shows the front pilot and railings bent along with the front walkway. (wunda bar)~
Name:	3 front pilot and railings bent.jpg
    Photo 4 Shows the rear pilot and railings are bent along with the rear walkway. (good times coming my way)~
Name:	4 rear pilot and railings bent.jpg
    Photo 5 Shows the rear pocket is pushed in pretty good. Wow, this model might look good on a layout as is (just like the prototype huh)~
Name:	5 real pocket pushed in.jpg
    Photo 6 Shows the rear truck touching tank. Hummm? What's going on here?
Name:	6 rear truck touching tank.jpg
    Photo 7 Shows the top lift rings got crushed as well. (I hope the engineer wasn't drinking hot coffee during this wreck)~
Name:	7 top lift rings crushed.jpg
    Photo 8 Show after grit blasting and repairing the pilot and some broke cast stanchions.
Name:	8 grit blast and repair pilot.jpg
    Photo 9 Show after grit blasting and repairing rear pilot area.
Name:	9 grit blast and repair rear pilot.jpg
    Photo 10 Shows after grit blasting all lifting paint chips.
Name:	10 grit blast all lifting paint.jpg
    Photo 11 Shows grit blasting all lifting paint rear and of course re-solder all loose joints as I go.
Name:	11 grit blast all lifting paint rear.jpg
    Photo 12 Shows no worries, even the prototype's has the same problem with shipping engines as well. (ha).
Name:	12 no worries even the real one was repaired.jpg
    Photo 13 Shows a lot of electronics just on the frame. This part covers the step lights and the control stand gauge lights.
Name:	13 a lot of electronics just on the frame.jpg
    Photo 14 Shows lots of wiring for the 23 leds on the model operated by 6 functions. (I had no choice but to use motor winding wires to cut down on space).
Name:	13.1 lots of wiring 23 leds on model on 6 functions.jpg
    Photo 15 Shows the prototype control stand with plenty of lighted gauges and buttons.
Name:	14.1 plenty of lighted gauges and buttons.jpg
    Photo 16 Shows the model control stand 3 color and truck lights lit up.
Name:	14 3 colored dash guage lights.jpg
    Photo 17 Shows weathering even in cab area.
Name:	17 weathering even in cab.jpg
    Photo 18 Shows plenty of detail decals also in cab and on the stand. (sorry I didn't take a close up here)~
Name:	18 decals also in cab.jpg
    Photo 19 Shows many texture weathering layers of rust peeling paint on the trucks, frame and fuel tank.
Name:	18.1 many textured weathering layers of rust peeling paint everywhere.jpg
    Photo 20 Shows the roof hatch with decals added.
Name:	19 decals everywhere on model.jpg
    Photo 21 Shows the yellow paint has two coats with two different colors using salt technique for weathering base.(Same for the black paint as well).
Name:	20 the yellow paint has two coats with two different colors using salt technique.jpg
    Photo 22 Shows so much attention to tiny details from paint to decals.
Name:	21 so much attention to tiny details from paint to decals to weathering.jpg
    Photo 23 Shows the roof paint with flat and gloss black using the salt technique.
Name:	22 many layers of weathering in the roof paint layers as well.jpg
    Photo 24 Shows space is at a premium with the decoder, cap-pak, cell phone speaker w/baffle and all resister/wires installed. Note: the cab light block which also allows cab interior lit up.
Name:	23 all tucked away in the small shell.jpg
    Photo 25 Shows even the fuel tank received weight and been shaped to clear drive line u-joints for 22" radius and no. 4.5 switches or bigger.
Name:	24 even the fuel tank received weight and been shaped to clear drive line.jpg
    Photo 26 Show the tank ends were shaped for clearances. Once painted it's hard to see from normal viewing.
Name:	25 tank end shaped for clearances.jpg
    Photo 27 Shows prepping the trucks to receive the all wheel pickup pads. Note: the gear boxes and truck level has already been adjusted prior to this point of the build.
Name:	26 prepping the trucks to receive the all wheel pickups.jpg
    Photo 28 Shows the truck side frames received plenty of weathering via the salt technique as well. Note: all 8 journals and springs were adjusted for smooth articulation.
Name:	27 the truck side frames received plenty of weathering.jpg
    Enough detailed build pics. Now it's time for some eye candy!
    Photo 29
    Photo 30
Name:	28 plenty ofTextured weathering on the roof top.jpg
    Photo 31
Name:	29 textured weathing is a part of weathering I think gets overlooked at times.jpg
    Photo 32
    Photo 33
    Photo 34
    Photo 35
    Photo 36
    Photo 37
    Photo 38
    Photo 39
    Photo 40
    Photo 41
    Photo 42
    Photo 43
    Photo 44
    Photo 45
    Photo 46
    Photo 47
    The End! I hope this pictorial gives you some modeling ideas or gives you an idea of what's really involve in rebuilding this type model. Remember always to properly pack your models when shipping.
    Thanx Thom...
    One question: What was up with the rear truck touching the fuel tank in photo 6?
      J~,
      Sorry in my haste to post all this (not knowing if I'd get kicked out by 403 for bidden) I didn't mention about a dozen other steps and that was one of them.
      The trucks were hitting the tank for two reasons: 1) the tank slid closer and 2) the plastic frame mounting spacer was slightly dented in the direction of the tank and when I tried to true round it again it broke from being brittle. So I had another one in my parts container.
      I'm planning to rebuild another one (engine this is) I have towards the end of year or first of next year when time allows. It will be a completely different build where I address the off center truck design and oversized drive shafts.
      T...
        Nice repair work.
          Thank you gorgeous George.
          T...
            thats an awesome model !! great work
              Nice rebuilding of your locomotive Thom, I'm always interested in your loco workings. That looked like it had a cornfield meet with a floor at some point in time.
                Thanks Boyz~,
                Ha, not a corn stalk in sight , but hey those shipping gorillas can really toss a package huh! AMERICAN TOURISTER - Gorilla vs Luggage Commerical 1980 - YouTube
                Thanx Thom...
