Building A HOn30 Diorama
  • #31
    Drew it looks fantastic, is the tall grass WS grass?
    • #32
      Thanks guys!
      John,
      I start with tan latex paint & sprinkle on real dirt that I sift through an old window screen…
      A primary ingredient for ground cover that I use is what I call my “debris bowl”…It’s an old plastic mixing bowl that I keep/throw all kinds of scenic materials in…ground-up leaves from outside, small twigs, bits of dried weeds, ground foam & other materials left over from all types of scenery projects…I also use some sawdust…the “loose rock” is just leftover bits of plaster …I also use plaster to make the rock outcrops…They’re just globs of p-o-p that I stick on the foam, & then I do a real rough carving job on it with something sharp…16-p nail, screwdriver, ice pick, whatever I can find laying around…this time I used a scrap piece of code 80 rail…
      The trees & foliage are a combination of dried weeds from the yard, plastic dish-sciuring pads, & WS ground foam…
      It’s a pretty low-budget operation…
      Lynn,
      Most of the long grass is jute rope…around here it’s usually called “bailing twine” You can get it at any hardware store…There may be some WS grass in there somewhere, because I do find it in my above-mentioned “debris bowl”.
      -Drew-
      • #33
        Thanks Drew,
        I have to get me one of those "debris bowls”.
        • #34
          Hi Drew,
          I enjoyed your description of a "Debris Bowl" I haven't quite got the same, but like you I use a mix of natural and store bought materials; they are kept in seperate conatiners though. Our major difference is that I use a brown acylic gap sealant as my base colour, but after that we do things very similarly.
          With the trees, do you use the scourer as the bases for your foliage? Would you mind doing a close-up photo of one of your trees thanks?
          Rod Hutchinson
          Growing Old Disgracefully
          • #35
            Thanks for the tip Drew
            • #36
              Originally posted by RodH
              Hi Drew,
              My trees are really a pretty sad affair…they’re just bits of dried weeds & flowers out of my yard & garden…I glue bits of ground foam to them for foliage…some of them I leave bare…
              The dish-scouring pads are these plastic mesh things that I cut up & tease into these clumps that look like something the cat coughed up!
              I spray paint them flat black, & then glue on some ground foam…
              When combined with the dried weeds, it (hopfully) looks somewhat like a wooded area…
              -Drew-
              • #37
                Drew, the difference between the initial and final states of the dish-scouring pads based weeds is amazing.
                And the last picture shows some GREAT modelling.
                • #38
                  Great idea with the scouring pads Drew, I'm gonna have to get me some. The finished area in the trestle photo looks terrific!
                  Steve
                  • #39
                    Thanks guys!
                    I've added a couple more details to the diorama...
                    Looks like the fish are biting down by the RR bridge...
                    -Drew-
                    • #40
                      Originally posted by Drew
                      When combined with the dried weeds, it (hopefully) looks somewhat like a wooded area…
                      Hopefully? I'd say definitely!
                      -Cody
                      • #41
                        TThanks for the scenery tips Drew. Yours certainly produce a most convincing scene.
                        • #42
                          Drew,
                          Are the two diorama pictures on page 3 the same diorama. There is something different about them that I can't put my finger on.
                          Rod Hutchinson
                          • #43
                            Stunning!!!
                            • #44
                              Very impressive.
                              • #45
                                The diorama really turned out nice, Drew. Thanks for sharing.
