Sunday!
  • #16
    Bruce,
    Good luck with the new toy.
    After you pick up your toy stop at your local hardware store and get yourself a heavy duty timer. The average block heater draws about 1500 watts. Set it appox 3 to 4 hours before you need the truck. That will give it plenty of time to warm up without killing the electric bill.
    Dirk
    • #17
      Dirk,
      Most likely, we will be ordering the truck equipped the way we want it. The delivery time is 8-12 weeks. That probably means delivery in February. Good thing that I'm a patient person.
      • #18
        Bruce...
        Dirk and I go back a bit here in Connecticut. Maybe we can coax Dirk into posting some photos of what he pulls around with that truck of his (hint, hint!)
        Russ
        • #19
          Russ,
          OK, you've tweaked my curiosity. What does Dirk pull with his truck? We're buying enough truck to pull a 5th wheel trailer--if we decide to go in that direction.
          • #20
            Originally posted by Dutchman
            Russ,
            Let's just say it's 1:1 scale and runs on real railroad tracks.
            • #21
              I have put one hundred thousand miles on a detroit and it is still going strong. only using a gallon of oil every ten thousand miles. thats a 60 series detroit between services. although some one else owns ot now ! I have seen two hundred fifty thousand miles on a diesel . The nice thing is the low RPM's let it live a lot longer than a gasoline engine and you have plenty of torque!
              • #22
                Dirk,
                I bet its closer to January. Depending on the good packages you ordered. The more stuff the faster they come.
                • #23
                  Russ,
                  Nothing like 12" scale. No parts to get lost in the rug. Just grease and rust. At the end of the day you smell like exhaust!
                  I will post a photo or photos of the Fairmont trackspeeders as soon as I figure it out.
                  Have fun.
                  Dirk
