This sawmill is heavily animated. The log carriage rides back and forth on a dot matrix print carriage bar. The main fixtures were made from CHB hardware and scale lumber. A steam engine that drives the lineshaft system is also animated. The boiler has a flame unit installed and is lined with fool's gold to look like glowing coals. The saw blade spins on a can motor and it will cut balsa. ITTC made the sound card for me and I added limiter switches to each end of the log carriage so the saw sounds only work while the log is in front of the spinning blade. The roof is covered in homemade corrugated cardstock. I just pressed thin business card stock between two sheets of corrugated Evergreen styrene sheeting to make them. I sprayed the pressed paper with Roof Brown and added Bragdon's weathering powders to give them the final look. They glue down fast and they're almost free.
