cant read it__all
  • cant read it__all
    when i click on some forums and read what an author has to say the text initally is fully on the screen.in a second or two the screen changes and i have to scrool to the right to read everything.i tried the ...view..text size..smallest.. but this doesn't help.anyone having these problem's? it doesn't happen on all the forums at this site,just a few of them.th in kansas.........
    id=quote>id=quote>
    Sometimes when someone has attached a large photo or map to a post, the page enlarges to accommodate the attachment. That causes you to have to scroll back and forth. It does make it hard to read the posts, though, doesn't it?
    http://homepage.mac.com/michael21/CMS-RR-Co./
      I have the same problem. Anything our "ADMIN" could do about it?
      Thanks.
      Modeling the Belmar Valley, a fictitious place served by N&W.
        The problem is the size of poeple's photo's that they post as Mike says, also the screen resolution you are using. If you increase your screen resolution to a higher level then it will not happen. Down side is that the text will be smaller and harder to see. Joe increased the text size for people back a few months because they were complaining it was too small. So if we want one problem fixed and it causes another problem it makes it very difficult for Joe. If he decreases the text size we will be back where we were before when everyone was complaining! If he doesn't then some people who use lower screen resolutions will have problems having to scroll! It's a no win situation. modelrr and Bruce try changing your resolution to a higher setting and see if this is acceptable.
        If using windows go to settings-control panel- display - settings tab - screen area and increase size to next setting.
        Also if we all keep in this mind when we post photo's and size them a little smaller.
        Modeling the NYC railroad
        (Not Yet Completed Railroad)
        Phil
          thanks phil and all.did what you said but real hard to read what's on the monitor even with my glasses on.will just have to live with this small problem.thought i was the only one having this problem.th in kansas........
            Th, I should have added once you change your resolution go into Internet explorer and click on view - text size and increase that, will help with the text problem without changing the scrolling. Sorry forgot that part in my first post
            Phil
              phil..thanks for the info.everything is ok now.th ............
                Happy to help!!
                Phil
                  I should call the computer police on you guys.BUSTED!
                  horailfan
                  horailfan
