Well,I thought I would share with you the way I tune up my Athearn drives.So here goes.
1)I start by turning the drive by hand using the flywheel to check on how smooth it turns.I check the metal contact strip at this time to see if it is making good contact,if not I gently bend it into place or hard wire it*.
2)I then proceed to use 1 small drop of oil on the shafts of the flywheels Again 1 small drop!!.I then turn the flywheels by hand to work the oil in place.
3)I then proceed to use 1 small drop of oil on the drive shafts at the joints,then I again turn the drive by hand to work the oil in.
4)I proceed to the trucks.I use 1 small drop of oil on the truck bushing,and gears.Again I turn the drive by hand using the flywheel in order to work the oil onto the gears.
5)I then turn my attention to the shell.On the inside top of the shell I add 4-6 pieces of A-Line stick on weight.This cuts down on the shell chatter,where alot of the Athearn noise comes from.
6)I then put the locomotive in a box lid that I turned into a engine holder upside down.I then put alligator clips on the drive and let it run forward for 30-45 minutes.I then reverse it and let it run another 30-45 minutes.this is done at slow speed.I then stop the locomotive,put back in forward and let it run at high speed for 30-45 minutes,then I reverse the locomotive and let it run at high speed again for 30-45 minutes.After this time I remove the locomotive and put the shell on.I then test run it on my test track.It should run smooth and fairly quite.
*As a option I may or may not hard wire the pick up.You choose the way that is best for you.
If you choose to try this the main thing to remember is use 1 SMALL DROP OF OIL-NO MORE!!!
I may do another topic on how to body mount Athearn locomotive couplers.I may also do one on Athearn car kits.
If you have any ideas or opinions that you use(no remotoring please as this is basic Athearn 101
and meant for beginners)
I will state I have use this method for years and find it works well.
brakie
brakie
