Fire Station??
  • Fire Station??
    Hello, I have never built any buildings from a kitbash or scratch, for that matter I am working on my first layout. Anyway I hav looked and looked for a fire station to house my equipment. The only ones that I have found have been small structures with only two equipment bays. I have 4 engines and one cheif car, So I need at least 4 equipment bays. Any Ideas on how to build a modernized USA style fire staion with 4 equipment bays. This might be to big of a task to tackle but I am willing to try. If someone will help.
    Andrew
    As a avid RR fan and professional Firefighter. I know How important it is to "LOOK, LISTEN AND LIVE" When approching RR Xings open your eyes, muffle the radio listen for oncomming trains It will save your life seatbelts dont help the impact of a train
    Hi, Andrew. If you can lay your hands on a Walthers catalog check out the Structures section and look at some of the Rix Pike Stuff buildings. They might meet your needs for modern and customizable buildings. I have built a couple and they're kind of fun to work with.
    Lou.
      I have the 2002 HO Cat. right here I will check it out. Thanx
        I found this article http://www.horailroad.com/clinic2/cl2_005.htm that might fit your needs if you can't find a kit.
          Check out the Rix website:
          http://www.rixproducts.com
          Is your glass half empty or half full .. or just too big?
          Which box am I susposed to think outside of?
            HI ANDREW: Also try www.dpmkits.com for DESIGN PRESERVATION MODELS, INC. You may find something there...Tom
            Tom in NH
              Andrew,
              You could also take one like Walther's new one and combine two kits into one firehouse (kit bash) it. http://www.walthers.com/exec/productinfo/933-2809 Taking 2 bays from one and adding the to the other, It would be easy to do with this kit just cut the front between the people door and the first bay and adding it to the other kit.
              Modeling the NYC railroad
              (Not Yet Completed Railroad)
              Phil
                I agree with NYC,the fastest and easiest way to get what you want is to buy two fire stations and put them together without the walls between them.That way you can build what you want until your ready to try your own structures. There are a few books on building your own and will give you alot of tips.Even genaric kits can be changed to fit your needs.As NYC posted this is kitbashing also. Have fun mostly!
                horailfan
                horailfan
                  I;m waiting for Rix to bring the PikeStuff fire station in N scale.The Pikestuff station is a 3 bay if memory serves me right.
                  Catt
                  Johnathan (Catt) Edwards
                  100% Michigan made
