Christopher, thanks for the "how-to" explanations. Neat idea for the pounce wheels.
A Great Scratchbuilding Project For Beginners
The chimney came out great. I like the "before" and "after" photos of the Weather-It treatment. An important tip when using Weather-It, always wait until it dries before passing judgement on its appearance. It always lightens up when it dries.
Great product though. I always keep a bottle of Weather-It and Blacken-It within reach at my work bench. Weather-It for wood and Blacken-It for metal. Love both of them.
Thanks,
Dave K in NB
I'm thinking about getting some of the "Blacken-It" to make metal castings black before painting them. This would give them a base coat of black without painting. One less coat of paint is one less coat to cover up details. What do you think about this, Dave?
Christopher [:-clown]
Clowning around with trains.
Exactly what it is intended for. The finish you end up with depends on the type of metal you are treating. Some brasses turn dark brown, some a little green. White metals alloys mostly turn black but if you let them dry and rub them a little they will have a nice "aged steel" look to them that is a great undercoat for paint and weathering chalks.
Here are a few examples on a G scale MOW car I built...
The hammer head, crow bar and pry bar are white metal dipped in Blacken-it then wiped down when dry. The screw jacks and tie plates are dipped then brushed with powders.
The oil can was dipped but not wiped (notice how it stayed so much darker).
I don't have a pic handy however with regards to those brass screws you can get at your local hobby shop from K&S, I have had some turn rust brown and some turn green.
All in all the unpredictability helps add to the affect (I think). If you are using Blacken-it on brass make sure that it is not coated with any kind of finish - it won't blacken - this can include oils from your hands if you handle the part too much prior to dipping in the solution. Also, burnishing the surface with 400 grit emery cloth prior to coating can yield interesting results.
Sorry, this is a bit longer than intended. Don't mean to hijack your thread. Good luck with Blacken-it, I think you'll like it.
Thanks,
Dave K in NB
Hi there. For days now I have been fussing and fretting with this window jig. I got one made. It's dusty in these photos, and the glue I used was the wrong stuff and left a mess. I had to make a new chopper as the one I made last week was not stable enough. The new one is brass and solid.
Here is the jig.
Say, it's warm in here. Will someone open the window.
Bound to get better when I start using my new chopper and get some more appropriate glue.
I got this system from Khamilton's web page.
http://public.fotki.com/khamilton/mo..._build_window/
Hi George,
I want tools I can't buy here. I don't have a credit card so no way to buy stuff on line. So I have to make my own.
First attempt at a chopper showed promise. But is too sloppy for precise cuts every time.
So I made one out of some brass stock. This one has no slop what-so-ever. A clean precise cut every time.
In this next pic you can see the triangle of brass I made to take out the side to side slop. 1/8" inside diameter brass tube and a piece of 1/8" welding rod make a nice snug hinge and base to solder everything to.
You will note on the wooden one that I have a taller fence and a stop is clamped to it. The problem I found with that is the fence is too tall and I was having a hard time holding small stock in place. So on the brass model I made the fence only about 1/16" tall, and this makes it easy holding small stock down while cutting. I carried the surface piece of bass wood out past the base so I can put a clamp on a stop if I want to. It's just a little bit different.
Now making windows is easy. I already made one complete window today. They look good inserted into the walls.
