Ken, the doors look great but they don't look like the original version with the cardboard behind it will there be more than one set of doors? Really like the look of the lintel, very well done, Pat
Pat, these are the same doors. They will be modeled closed. I just cut out the window openings in the cardstock. I did this because the interior will have light along with one above the door.
LVRALPH, the wood was given a bath in some A&I, allowed to dry and then painted with a very fine brush to make it look like peeling paint.
Bruce, that would be too easy I really want a painted on, faded sign. Since the letters will be fairly large I hope I can pull it off. We'll see....
A box of detail parts finally arrived so I've been slowly adding them to the building. Still need to paint and weather the lock.
I ordered some hinges, but they are really too big (imagine that) and thick. You would think door hinges would be easy to find with all the dollhouse stuff around...not! So I might end up making my own or use O scale stuff.
Was wondering if you guys think the door and window should have trim around them? They fit real tight with no gaps to the walls but I'm undecided if I should add them or not.
