Off to a rocky start there...good start
Caz Coal -and- Wood
Karl thanks, it's a start while I wait for the track.
Michael thank you. Glad you like the look; being my first time doing this I wasn't sure.
Rick and Jerry thank you. I think you're right about the right end. The corner will be fixed after I get the right look and glue the two pieces together. Then add some caulk to blend the two together and touch up with paint.
Bill thanks for stopping by. I have to confess that I had no idea what you were talking about so I had to look it up. If I understand it correctly it sounds like a trough that would develop over time due to water running down the rock. I'll have to see how I can add that as well; thanks.
Larry, my fault, trying to sound all science-y.
What I was trying to say is it seems like over time all those layers of rock you modeled so nice and level and straight seem to get tilted and/or distorted and bent by the massive geological forces pressing and squeezing them.
Here's a tunnel through slate on my layout. all the layers of slate have been tilted up on the right side as the big hill got pushed upward a zillion years ago.
And here's a photo from Bernd's Kingston Model Works site. In the background is a long rock cut through "limestone" (ceiling tiles). You can see on the left side the layers are wavey, not all flat and straight.
That's what I meant.
- 1 like
Larry,
Here's the page I started explaining the use of ceiling tiles that Bill mentioned to me. He also told me nothing is absolutely straight in nature so I tried a different approach.
http://www.railroad-line.com/forum/t...42&whichpage=4
Thanks for the shout out Bill, appreciated.
Bill thanks for the photo; much appreciated. Well I wasn't even close on my interpretation but I decided to carve an indentation going down the rock face where water would have run down over time to make the indentation. I don't think that I can do as the photo suggests with what I have but can definitely use it for the rest of the rock.
Bernd thanks for stopping by and the link to your project. Actually I had already seen it but since I had a lot of foam left I thought that I would go this route. By the way your rock work looks impressive.
Larry,
Although folded and tilted strata are interesting to look at, lots of regions have almost perfectly flat rock layers.
Where I went to graduate school in Indiana the limestone formations looked pretty flat. Even in the Finger Lakes region where I grew up the strata were generally flat-lying with gentle folds like Bernd modeled.
Michael thank you for the explanation. Now that you mention the flatness, going east on the NYS Thruway past the Mohawk Valley the layers of rock are fairly flat. I think that I'm going to make some adjustments on mine and have the layers slightly angled just for some interest; but not to the extent that Bill has his.
Larry,
As I was walking along our nearby rail trail looking at rock outcrops, I thought about your hill. I think what is missing is a rounded-off hilltop with weeds, grass, bushes and trees. I think that would look more realistic than a small house. Keep things simple and focus attention on your fine structure.
