Building Gondola Cars
  • #31
    Martin,
    Very nice.
    I see it's lettered for the No-Name Railroad: it must be headed for the sales table.
    If you had a model of a car shop you could pose these fine models in front of it like prototype builders did.
    • #32
      Very nice.
      Thanks, Mike!
      Possibly; undecided as yet and I can always drop some dry transfers on it for the CVRR.
      Interesting idea, Maybe I need to do just that.....and then find a place for that to gather dust in my shop,
      In the meantime, I have to wrap up the other gon in this pair so I can get into the next pair....
      • #33
        And, now this one is done, too.
        • #34
          Very fine gons, Martin. :up:
          • #35
            They look good, Martin. How are you doing your loads?
            • #36
              Some blue foam cut to fit with a bit of sheet lead glued to the foam; wrapped in painter's tape and glue applied with ballast mix added on top of that - let dry, and then apply matte medium to entire load. Let dry, peel tape, insert into car. Done!
              Same for my real coal loads.
              • #37
                Well, I think I've got this sussed out now, I hope! Off to the next gon that I've built then...
ID:	962440Click image for larger version
                • #38
                  Took me a bit to figure out what gondola build this was that I was doing back in April, but I've got the photos matched up now...
                  Got the sides on next:
                  • #39
                    Following along, as before.
                    • #40
                      Also on board.
                      • #41
                        I'm here also looking over both their shoulders. Hey Bernie, can you move just a scosche to the right?
                        Thanx Thom....
                        • #42
                          Thanx Thom....
                          Oh, my other right?
                          • #43
                            Lots done; stake pockets, nbw's, bolsters, needlebeams and queenposts, corner castings,.......K brake mounted; co
