New source for 3D printed arch-bar trucks
  • New source for 3D printed arch-bar trucks
    https://3dptrain.com/Creator/zmw/
    I've never dealt with any 3D items. How durable are they for this kind of application?
      I wonder how many you'll break trying to get wheel sets into them with the those brake beams on the end. I wouldn't think they would spread to far. Of course it also depends on what kind of material they are made from. From my current foray into 3D printing I hear that the resin is brittle if exposed to UV light for any length of time.
      It be interesting to purchase a pair without wheels to test out the theory at what point they break.
        Originally posted by George D
        How durable are they?
        They are fine. I mean they are strong enough. I find them stronger than the 0ld Red Ball cast metal versions offered by others. Only problem is their lightness.
        My experiences are with those printed by Shapeways and not this shops products.
        It's only make-believe
          I work at a product design firm. We have two SLA machines and a FDM machine. For the SLA machines which use a laser to cure the resin, we have about 8-10 different types of resin.
          Some resins are flexible to simulate rubber, some are more rigid like glass filled nylon. So really it depends on the type of resin they are using. We have resins that are very durable,
          you can throw them against the wall and they won't break. I recently grew some Z scale tender tops out of three different resins. They are most likely using a durable resin, but you can
          always ask, and then look up the resin.
            They look interesting Just ordered 3 of each of the HO archbars.
            Howard Garner
              Originally posted by CNE1899
              Can a moderator remove these extras?
              You Can. IN the list of Icons above YOUR post the last one is to remove the post.
                Thanks Bob.
                  If you file a small notch in the bottom of the journal box on one side, just enough to relieve the amount the trucks have to spread, it makes installing wheelsets much less prone to breakage.
                  Dave Husman
                  Iron Men and wooden cars
                    Never thought of that. Thanks Dave.
                      You don't need to file any notches in these. I took the product photos that are on the website. There is plenty of physical tolerance and flexibility in the material to allow wheelsets such as Kadee, Intermountain (what is depicted in the photo) and ExactRail to simply slide in place. Many UV-cured resins used in hobby applications now behave like normal polystyrene plastic.
                      I've used 3D printed trucks from several sources, including a few shapeways sellers, and only broken one, even with the simulated body-mounted brake beams. In the case of the one that broke, that was not due to deficiencies in the material nor design but rather simply my fat fingers putting too much pressure on it while making a modification to match a specific prototype.
                        My six set arrived last week. Installed both Tangent and Intermontain 33" wheel set with no problems. they are flexible enough to work
                        One had a mis-shapened journal box. Notified the vendor and it was quickly replaced.
                        Now just to figure out what cars to put them under
                        Howard Garner
                        modeling 1905 in southern Minnesota
