I read an article in a recent Model Railroader that talked about making foundations for structures as a way to make them fit better into the scenery. After thinking about it and knowing I need to raise the passenger platforms I decided to give it a try. The article recommended three materials to choose from; wood strips, foam board, and plaster with or without a façade. For my purpose I chose the foam board.
Using the base of the platforms I traced the outline and cut the foam board. The type of board I chose required two layers as you can see.
Since there are four platforms I had to cut a total of eight pieces.
I had to cut out for the stairs in two of the platforms.
I placed the boards and the platforms and checked the height against a passenger coach.
Checked to make sure the cuts for the stairs were done correctly. When the foundations are in place I will use scrap to fill in the gap.
The platforms are too far from the rail. The little plastic people would have quite a jump to board. Therefore I have to remove some of the roadbed edge.
All the roadbed edge removed for the platforms.
Test of the platform location.
Next I need to paint the foam board black. I also need to figure out a way to keep the ballast out of the area of the foundations. I don't want to set the foundations until the blalast is in place as I don't want it spilling onto the foundation and creating problems with setting the platforms.
