Looks promising Scott. Looking forward to your next update.
"Choices Challenge" Bench Work For My First Layout
I cut out the weighted handles that are on the end of the switch (Racor #2). I cut these from a scrap piece of aluminum. Drilled and filed out the area for the hand hold, and drilled the hole to attach to the lever arm. Next I'll radius the edges and epoxy them on.
Update,
Received the ordered 8-32 carriage bolts. Drilled and filed square the carriage bolt holes
Roughed out the lever hand holds, drilled hole for lever and cut the heads off the bolts.
Press fit the hand holds onto the bolts.
Drilled pilot holes into the base sides and drilled holes for the carriage bolts in the base front.
Assembled the lot.
Know I just need to sand the base and stain black. The control panel and controls will be flat black.
I am not sure if I am going to paint the brass and bronze or not.
- 1 like
Soooooo,
Looks like this will be the only project I will finish for the challenge.
I stained the frame and painted the switches and control panel.
The holes along the bottom will be for block switches.
The main line and four sidings will be controlled by the on/off knobs.
The internal linkages will be installed along with the switches.
Thanks for following.
