So onward with the small boat builds.
I've scratchbuilt a couple of outboard motors, to sort of look like Johnson seahorse models from the '50's.
Had to really think outside the box for these.
Needed something kind of egg / football shaped for the main body, so used a wooden bead.
The shaft is a bootlace ferrule, for electrical wiring. and the rest is styrene. I even made the prop myself.
Undercoated
And painted. I also mad a fuel tank from square styrene tube
Then onto the boat. Had to add a bit of styren at the front of the hull bottom to make it sit level, as to original had a curved bottom
Painted white and a red line around it to give a bit of colour.
Improved the interior from the original model. Added a plank floor and side stakes, and painted
Undercoated
