The expectation for this corner of the layout is that the HOn30 track in the back climbs up the hill to the left (hidden behind trees, etc, at times to draw out the short run). There's a scenic divider to the left mocked up by the styrofoam(the HOn30 lines passes through it), and the backdrop will fill pretty much to the height of that divider along the back wall. Where the divider is, I expect to do thick trees on top of a ridgeline, rather than a scenic backdrop.
So I've been throwing big wads of newspaper to imagine the landform within those constraints. In particular, I'd like to get a creek that comes down from between the hills, crossing underneath both the rear HOn30 and the front HO track.
On the far right, you can see a piece of backdrop that shows the approximate height of the tree line that will run all along the rear of the scene.
I need at least one more day's worth of newspapers to get all of the rough landforms in place :-)
Comments very much welcome!
