  • I can't watch anything close like wood work, without bifocals... it hurts my eyes.
    Needs some paint and grass...
    ..... to watch one dry, and the other to grow.
    ..... without bifocals!
    • Rich, Carl, Pete, Mike, Fred, Dave, Scott, and David, thanks for your posts, they keep me going.
      Here's a little change of pace, I set the front aside for a bit. Back in the 30's many store fronts had
      some of the window panels in stained glass (such as above the show window and upper window sections).
      I googled "vintage store front stained glass" and got hundreds to choose from. Most were not usable but I
      picked a few I liked, cut them in pieces, stretched and resized them, an made a few corrections.
      I used to print this kind of stuff on overhead slide material on a laser printer but I noticed lately that the company
      that I buy my LEDs from is offering some paper materials and one of them is sheets of clear plastic suited for
      ink-jet printers so I tried some. I think they worked out great.
      I printed them on paper and was able to check them for size and fit on the front. I made some adjustments and
      then printed them on the new material.
Name:	13 decals.JPG
      I always make more than I need because I usually mess up a few.
      • Bob, those stained glass accents are going to look terrific . Do you have to spray the inkjet prints to keep them from smearing?
        • Bill,
          The real answer is I don't know. The instructions say it is optional to spray with a fixative, I simply sprayed them with clear gloss.
          They do not smear or rub off. Next time I print some I will test one without spray.
          • Bob, "WOW!!!" doesn't seem to cover this, but it's all I have right now, so "WOW!!!
            Very nicely done!
            • Bob,
              Amazing job making the windows. You're going to have a very classy storefront.
              • Bob, those stained glass windows look amazing! Wonderful work!
                Greg
                • the company that I buy my LEDs from is offering some paper materials -
                  Looks great Bob! Can you share who that company is?
                  • Bob,
                    Very impressive stained glass windows!
                    • Great looking stained glass windows. Some info for future use.
                      • Pete, Mike, Greg, Carl, Dave, and Bernd, thanks for your posts, much appreciated,
                        I too am impressed by how well it took the ink-jet printing.
                        Carl, The company is evandesigns.com
                        • Very nice! I've wanted to include some stained glass on my models for a long time but haven't yet figured out a way to do it that could handle being outdoors and exposed to the elements.
                          • Ray, That has always been an added problem for you to overcome, I do not know how weather resistant these would be.
                            I have discovered what might be a problem with these stained glass windows for some modelers. As I have said, the instructions
                            mention an optional last step of spraying the printing with Krylon 1305 UV resistant Clear, that might be the answer.
                            However, a warning. If you want to have a plastic sheet representing a clear window with some areas printed as stained glass
                            or any signage, spraying with regular clear gloss as I did is not the answer. While the printed stained glass looks fantastic
                            (I am still going to use mine as is) I have noticed that the clear areas outside the printing have turned whiteish.
                            Please note that even without spraying the clear areas do have a very slightly foggy look but I do not thing it will be noticeable
                            when used as a clear window.
                            • I'm looking forward to the build and the whatever follows in Volume 5, Bob.
                              • Bob,
                                Those stained glass windows are beautiful! Thanks for mentioning who sells them.
