  • Bob,
    Looks nice.
    This is timely. I'll be doing Z scale paper brick on the Pleasant Valley Locomotive Works.
    • Nice to see you modeling again, Bob! I'm looking forward to seeing what you do with this one.
      • Dave, Greg, Pete, Scott, and Ray, Thanks for your comments, Sorry, this is going to be a SLOW one due to my shortened available work time.
        Ray, one thing that is not working for me on the new forum is the email notification of posting to builds. If you start one please
        send me an email heads up so I can know to follow along.
        • Originally posted by sgtbob View Post
          I haven't started a new one but did post an update on my hardware store build:
          https://railroad-line.com/node/39574...319#post971319
          • Ray, Outstanding again!!! I have saved the address so I can check on your progress every day.
            • Click image for larger version
Name:	3 wall A.JPG
Name:	3 wall B.JPG
              I did get a little done on this build. That extra piece for each wall will be glued inside at the top where it will double the
              wall thickness to a more realistic thickness. The bottom slanted edge will make a place for the roof to glue in.
              Since the lower half of the brick wall will be covered up by an adjacent shorter structure I decided to cut in a
              window in he upper half just to be more interesting.
              • Nicely done, Bob! The window seems like a Good Idea to me! Keep plugging!
                • Bob,
                  Nice forethought on the edge for the roof. It's details like that, I forget.
                  • Pete and Scott, thanks for your posts.
                    Click image for larger version  Name:	4 shell 2.JPG Views:	0 Size:	115.6 KB ID:	972122
                    Click image for larger version  Name:	4 shell 1.JPG Views:	0 Size:	144.8 KB ID:	972121
                    The two sides were glued into slots along the sides of a GatorBoard base and held squarely in place with several heavy metal 1-2-3 blocks until the glue dried.
                    Then the first floor ceiling and the roof base were glued in place.
                    The result was a nice square form on which to add all the details. That section out front is the base of the sidewalk.
                    • Bob,
                      Looks stout! The brick looks three dimensional in the first shot!
                      • Good morning Bob,
                        I wanted to send you a "thumbs up" but I can't find the symbol on the new system!
                        • Bob, looks like it's shaping up nicely. I'm just happy to see you here back at work again!
                          Greg
                          • Bob, Glad to see you found a project and already made a lot of progress on it. The ghost signs are neat. Following along.
                            • Very nice!
                              • Looking good!
