There is a problem with the one sheet of planks that is in this kit. I don't know if
you can see it here but where the laser skipped to leave a little section to hold the planks
in place on the sheet it did not line up perfectly. That meant that I had a choice, I
could either trim each plank to make it smooth or I could leave it go and fix it
later with a little filler. I figured I would do more damage trimming the planks and I know
I will be using filler in other spots anyway. If you are building the model the choice will be yours.
