Lou’s Logging Split Camp Store
  • Jerry, Larry, Ron, Mike and Bruce thanks so much for your posts and comments, as well as following along with this build.
    Jerry, it's great stuff once dried, but can be difficult at times while trying to get it on.
    Larry it will work equally as well on O scale window panes. See here where I used it as a vehicle window glazing, a hole much larger than O scale panes: https://railroad-line.com/node/23455
    Ron, the liquid does look puddled and thick when first put on, but shrinks to a fine old time glass effect.
    Mike, thanks!
    Bruce thanks for your thoughts and comments.
    • Nice work, Louis. I've tried all those different glass glues. Just depended on whtat I had at the time. All with similar results.
      And the by-product is, you've got that slight ripple look, so common in old glass.
      I prefer clear plastic for my windows, but as you said, being visible inside too, it wouldn't look right.
      Good result.
      • Originally posted by robert_goslin View Post
        Good result.
        Thanks a lot Rob for your following along, posts and comments. Click image for larger version
        • That Gallery Glass looks like a winner! I've used Canopy Glue in the past, but your panes look far superior than the Canopy glass I've used. Excellent job Lou!
          • Thank you Jim!
            • I am a little late on this thread but.......the building details, window frames and glass effect really look neat. Nice work my friend.
              John Holt
              GULF COAST & WESTERN
              • Hello John, thanks for your comments, leaving a post, joining in and following along.
                • I’ll be covering my split camp store with tarpaper material. To start with, I cut a piece of cardboard to measurement for the roof. I then marked off lines where the tarpaper will line-up across the roof, and colored the bottom with a brown sharpie, that will be seen through the rafters from the inside, and colored the edges that would be seen under the tarpaper. Then I used black construction paper from Michael’s craft store, and lightly sprayed/misted a covering of grey, flat black, and olive drab paint misting the construction paper to get the base color wanted. Some monitors may not show the exact color, but picture is attached. Next, I cut strips 3/8 inch wide from the construction paper for my tarpaper width. Then using a 220-grit sandpaper block I lightly sanded down the length of the strips, from top to bottom of the strip width to add to the weathering and direction of rain runoff. Next, using a fine wire brush and X-Acto knife I picked and brushed the bottom edge of the tarpaper strips. You can be as aggressive, or as mild as you prefer for the old age look. I used plan old Elmer’s glue to glue down my tarpaper onto the card stock, and added weight until dry.
                  After the tarpaper has been dried down in place onto the cardstock roof, you can trim the sides of the overhang tarpaper. Once the cardstock roof has been glued onto the structure, you can further weather the tarpaper using weathering powders until you get the look you prefer.
                  Next, I’ll be gluing the cardstock roof onto the structure, doing some weathering to the walls of the structure, and return with pictures of my progress.
Name:	35 Roof cardboard.jpg
Name:	36 Roof paint.jpg
Name:	37 Roof tarpaper.jpg
Name:	38 Cutting-Sanding.jpg
Name:	39 Tarpaper install.jpg
Name:	40 Tarpaper trim-finish.jpg
                  • Louis,
                    Your use of the gallery glass came out perfect. I've tried a similar product in the past, and it works ok if the window openings are not too large.
                    In other models, I just resorted to using real glass slides, but with the cutting & scribing processes we have to go through, it's not great unless you take
                    considerable time because the glass never breaks where you want it to , leaving you frustrated. If that method works out, it is great, but not all end up being the same, like yours.
                    Great modeling and looking forward to the next segment.
                    • Roof is looking great Louis,
                      I saw those Sharpie paint pens at Micheal's the last time I was there and they seemed promising. After seeing your results, I just might have to get me a set.
                      http://cvry.ca
                      • Looking good Louis. Nice SBS on the roof tar paper. I like those Sharpie pens as Ron said.
                        • Originally posted by Pennman View Post
                          Louis,
                          Thanks Rich for your comments. It will work equally as well on O scale window panes. See here where I used it as a vehicle window glazing, a hole much larger than O scale panes: https://railroad-line.com/node/23455 You can see how well it works and covers the opening.
                          • Originally posted by elwoodblues View Post
                            Hi Ron, and thanks for joining in and leaving a comment. Yeah, those pens come in handy for a quick, get-her-done type of project.
                            • Originally posted by Bernd View Post
                              Thanks Bernd. Some say I tend to drag on my SBS instructions, drawings and pictures, but I feel any and all information should be thrown out there, due to there being many type of modelers from new to scratch building, to the very old types.
                              • If we had thumbs up smilies I would give you one!
