Construction of REAL wooden buildings (Walls)
  • Construction of REAL wooden buildings (Walls)
    I am hoping to do something in O Scale (On30)
    Welcome to the forum James.
    What are you planning on building? You can lots of help here just let us know.
      I thought I had posted an actual question instead of a statement. But it seems to have been lost in the ether. Sorry for the confusion.
      I am from the UK and would like to know what dimensions of wood are used in real life for the construction of the various type of wooden structure. I am thinking about board and battern, clap board and another type (I don't know the namer it but it is just simple vertical boards over a stud Frame)
      With this info I will know what size lumber to order so that I can try a little scratch building (Board by board construction not sheets of clapboard )
      I want to build something in O Scale. Something like Sierra West Scale models o'Neill's Fabrication.
      I have never built anything much before except a Fine Scale Minatures kit and that was 40 years ago!
      I want to experiment with techniques before spending a fortune on a kit.
        In the US, residential construction is either 2x4 or 2x6 (2x6 in colder climates, to allow for more room for insulation.) That's nominal lumber size, the measured size is 1 3/4 x 3 3/4. They're done on 16" centers. http://www.visualdictionaryonline.co...ouse/frame.php
        That horizontal siding is probably 'shiplap', which has a tongue and groove arrangement to keep water and cold out. (Shiplap is very trendy for interior walls these days :-) ) So from a distance, it looks like horizontal boards butted against each other.
        For board and batten, you'd have to do a somewhat different style of framing, to have enough horizontal members to nail the boards to.
          Brett of Sierra West models Has a Forum That I would sign up for and join Tons of info there on weathering and Great Modeling.
          Were we go one We go All
            Thanks for that.
            I am particularly interested in trying to replicate the blue stained walls on the from of this building from Sierra West Scale Models Gallery :
            https://sierrawestscalemodels.com/ga.../311_jf_01.jpg
              Thanks Craig. I have tried but there is a problem with his site as far as I can tell as of writing this . I cannot register.
              A ReCaptcha bug as far as I could tell. But I have emailed him.
                James,
                Framing and siding dimensions Depend on your time frame, age, size of building and type of construction.
                Pre-1900 construction would have been post and beam with heavy timbers for the skeleton, and 2 by 4 (actual) studs for residences, heavier for large wood buildings, for instance 2 by 8 for shops and enginehouse. Framing changed over to balloon framing and modern framing with 2 by 4’s in the late 1800’s for residences.
                You know about clapboard and board and batten, and Dave told you about shiplap, used in late 1800’s and thereafter. Board and batten probably used varying board widths from building to building but 12” was typical. Battens about 2” wide.
                I don’t know if there’s a name for vertical boards on a frame. They are typically for very informal buildings, as you’ve probably observed. Boards can vary in width even on the same building, but 12” or thereabouts was typical
                Sheathing can vary in thickness. The clapboard is around 1/2” on my old 1859 house. I think anything up to 1” is reasonable. I usually use 1” scale lumber. It’s purpose is to keep water out and does not have to be thick, unless it’s for a coal bunker, in which case 3” is appropriate, maybe thicker.
                Mike .
                  That looks like a building where there are no set rules. Sheathing looks to be 8 to 10”. I think you could do what looks right to you.
                    Thanks Michael. That is very helpful.
                    Right! I am off to HandLaidTrack.com to get me some lumber.
                      You’re not the first to scratchbuild this kit, and I’m sure you won’t be the last:
                      http://railroad-line.com/forum/topic...rms=O%27Neills
                      It’s a great place to start.
                        Wow. I don't fancy having to follow that!
                        Excellent work.
                        Thanks again Michael.
                        These forums are truly amazing. So much help from so many really friendly people.
                        And this has been my first question. I only joined today!!
                          James, you might try this one;
                          http://www.railroad-line.com/forum/t...TOPIC_ID=52790
                          He's building a kit but he gives you enough information to scratch build it (like I'm going to).
                          It\'s only make-believe
                            I started a thread on building a wooden structure. I never finished it, but the thread may be some help to you. I used 1/4 x 1/32 rosewood strips for mine.
                            http://www.railroad-line.com/forum/t...TOPIC_ID=41764
                              Thanks Bob. I will have a look at that. Not a structure I was particularly looking for but it does have nice proportions.
                              Ron. That looks like an epic piece of modelling. Very neat work. I haven't heard of Rosewood for modelling with. I will study it with interest.
