I really enjoyed your video. You got a lot done. Your cabooss........I mean way cars came out great. It's kind'a sad that so much track is ending up in the mountain.
Thanks Bob, Rich! I've always tended to have a lot of hidden track in my track plans. Probably that's not a good thing, but I can't seem to shake the habit!
I've spent most of the last two weeks working on the Wind River Canyon. If you watched my latest video, you know I started adding plaster cloth to the south end and the area between Powder River and Shobon:
I've since continued adding to the foam sheet scenery base, extending northward into the canyon. By the 10th I had started on the canyon wall beside the first tunnel, Tunnel 4 (or "Black Tunnel" to the train crews), and roughed in Tunnel 3, to the right in this shot:
By the 13th the wall between Black Tunnel and Tunnel 3 looked like this, and I was progressing on northward:
And as of 17 May the canyon looked like this, looking back from the end of the peninsula:
I'm about ready to start carving on the foam in preparation for adding plaster cloth.
You can see in the right foreground that I switched from a solid stack of foam to an open cribbing build style. I've used about three sheets of foam to this point, and will need at least two more just for the open cribbing, which uses a lot less material. Foam sheets have gotten expensive lately, along with everything else. A 1-1/2" X 4' X 8' sheet is almost $33 at Menards these days.
That will be quite something when finished. I've only visited Wyoming by train, no idea if I'll ever drive there, so your model will complement the photos I see on-line.
I crossed Wyoming several times aboard Amtrak via the UP: Evanston to Cheyenne, then south to Denver. But one time the BN line was snowed over east of Denver and we went to Lincoln NE via the UP instead. Another time we rode a UP steam excursion out of Denver to the rodeo in Cheyenne
By 20 May I carved off most of the sharp corners of the foam blocks using a hot wire cutter. It also goes right through low temperature hot glue.
Then I abraded the foam surfaces using a Surform tool. This tears out little chunks of foam and leaves a very rough surface the plaster cloth can grab onto.
And finally, on 25 May, I added all the remaining plaster cloth I had on hand - nearly 30 pounds worth. That almost 100 linear feet of cloth.
Next step in this area is to add a layer of hydrocal (thick in most places) to carve into rocks on all the vertical and near-vertical surfaces. That will hide the step-like horizontal lines left from the foam blocks. The hydrocal is on order (can't get it locally) and should be here in a few days. I have 50 pounds on the way. I'm sure I'll need more.
As you can see by the last picture, I have a lot more canyon to go. Where the foam tapers down in the background needs to be built up a lot more, but I ran out of foam panels. I won't be adding more foam for a couple months, but I have plenty else to keep me busy in the cloth-covered area of the canyon.
