Thanks for the suggestion, jbvb. I spoke with BLI Tech Support and apparently this is a known issue with many of their Consolidations. They offered to replace the decoder at no charge. I opted to start with a keep alive first (what they call a "Go Pack), since all my turnouts are dead frog and I was planning to do that anyway. Tech Support said that should resolve the problem, and if it persisted I should call back and they will still replace the decoder. So in a week to ten days the Go Pack will be installed (it's plug and play on my decoder) and we'll see what we see. Stay tuned...
The CB-and-Q in Wyoming V5
Thanks Bob, Rick and Mike!
23 October 2021
We took a vacation in mid-October, but now I'm back at it!
In early October I began extending the benchwork westward out of Casper towards Thermopolis. I got the grids built and installed for Powder River (in front of the camera) and Shobon (to the right).
I installed the backdrop, then placed 1 1/2 foam for the sub-base.
Roadbed went down, and we went on vacation. It wasn't a railfanning trip unfortunately.
After we got back I installed new track on the curve leading away from Casper, and tested it with an 0-8-0 switcher and a boxcar out of Casper.
- 1 like
29 October 2021
I added the first section of Wind River Canyon / Thermopolis benchwork:
This is the first of four sections.
I also transitioned from the foam roadbed to 1/2" plywood. The foam is notched and low temp hot glue applied. Then the plywood is pressed into place. A riser under the plywood near the transition serves to stabilize the joint.
Yesterday I finished laying the Powder River spur. On the prototype its sole purpose was for livestock loading (though during off seasons the railroad may have stored a few cars there), and so it will be on the layout. The spur holds up to eight stock cars, which seems like a pretty fair amount for the layout. One load will make for a small, but not overly-diminutive, train.
I have a friend who likes weathering locomotives, and he's done several for me. He returned this one plus two others last week. I added some Bragdon brown weathering chalks to "dust up" the locomotive you see here, a Heritage Proto 2000 Santa Fe type.
- 1 like
Brunton........What are you using as your "super elevation tape"? I have thought of using wood or plastic strips for this effect, leaning more to the plastic strips. But that could get expensive with the price of styrene strips and the shipping. The tape idea looks good to me. Thanks....JohnGULF COAST & WESTERN
