Mystery Scratchbuild
  • #46
    Originally posted by George D
    Yes! I'm actually looking at a plate of Ravioli and Italian sausage. [:-chef]
    You're making me hungry, are you sharing?
    Bring a fork!
    • #47
      Jim, are you looking at something like this?
      Thanks for this drawing. It may solve a roof problem in my future.
      • #48
        Bernd, I was wrong, it takes 9 segments to make 180°. The straight sections of roof connect the two 9 segment pieces. I'm on my laptop, so I can't correct my drawing.
        • #49
          Here's the corrected copy.
          • #50
            George,
            I don't see where you are getting 9 segments. I get 7. That would be 25.714 degrees per segment.
            • #51
              Good grief, I need a cone head hat, all that high end mathamagicicall whizzardry...You know you'll need a circular interface underneath so this roof will fit down snug on the pottery tubes....
              • #52
                Try connecting the towers without the 'straight] #0 & #8 and you will then see why you need an 18 sided polygon to do it. The panels are 20 degrees. Where do you get a 25.714 degree jig to build this rascal?
                • #53
                  I divided 7 into 180 = 25.714. I'd draw a segment with a 25.714 or 25.7 degree, print it out and use that to build a jig.
                  Now you got me interested to see if I can draw that in CAD.
                  Edit Added:
                  Ok, here's my drawing with 7 segments of 25.714 degrees for each segment.
                  • #54
                    You're right, Bernd, my count is off.
                    • #55
                      Can you see the difference? The latest rendition is a divided circle, the previous example was drawn as a polygon. The carpenters back when the roofs were put on would have used a simple 20 degree angle. CAD wasn't even a thing! It's 18! It's aaaaaaaaah mystery!
                      • #56
                        Personally I don't think they used any kind of dimension. If you look at segment 3 and 5 you'll see that they are different than segment 4. Segment 4 looks narrower on the bottom than 3 and 5. Or do I need my eyes recalibrated?
                        • #57
                          Looks like now I have to drive to Bergen, rent a htdraulic lift, bring a huge st of calipers and a adjustable bevel square and measure them. Then find out who the contractor was, hire an attorney, only to find out it was a high school 'shop project'.
                          I'll get back to the build tomorrow, I just came off the roof after getting a 'Charley horse' up there. Yeow! It was a lot more fun 40 years ago.
                          • #58
                            If you use a flat drawing that all connects , you will not gain the height of the cone.
                            Think of a hexagon or octagon. Remove one segment. Now close the remaining ends back together.
                            Unless the center goes upward to form a cone, you can't do it. If you keep ALL segments it must remain flat. One has to be missing.
                            That's why the original drawing by George is correct and the subsequent drawing by Benrd will not work properly. You need that missing segment to form the cone.
                            I have already printed out, and formed Georges drawing, It works. But there is an easier way though to cut the shape, which would include tabs for gluing. I have modified George's original drawing slightly to show it below.
                            Try it it works.
                            (If you want more room for the endless bucket loader in the middle, or third silo just extend the length of the rectangles as needed.)
                            • #59
                              Trying not to sound snarky here but, I started this thread to show how I go about building a model using the 'additive manufacturing' process
                              aka 3D printing. I'm not cutting materials.
                              • #60
                                Good luck on the roof. They took it off last year. Anyway, back to lurking and watching you finish those silos.
                                And stay off the roof. You're to old to be up there. [^]
