Thanks for all that responded. My connection just took a dump, and the blurb that I had so carefully constructed just went the way of the TP. :erm:
Continuing...the above picture tells the story of the computer, but when it comes to the reality of it. This was the result of the 228C molten ABS that
printed out. There are 288 3.5mm squares, .7mm high, on a .4mm backstrip. The squares positioned .2mm apart.
Not what the computer displayed in the 3rd shot. But with some light sanding with 320 grit sandpaper and a coat of gray primer, they start to look good.
After a little hand painting the mystery should be solved. (Karl actually solved it yesterday via PM. (Can't keep an old sleuth down.
More later.
More later.
