Fine job, Jim. Your way of building and painting the silos is particularly realistic.
Thanks Mike, As I look at the 'overhead view' the gravel path is bugging me. Too much deviation, and the end that meets the 'up' part of the ramp, is weird. Some rework to place it, would be necessary.
Rich, I built one of those DIY applicator for about $20. Amazon/eBay high voltage module, some PVC pipe (also used for the silo innards, a Walmart snack container, and a circle cut out of a strainer. About an hours worth of assembly, and much nicer than the Harbor Freight flyswatters I've seen. You'll need a 12 volt wall wart to provide the power.
Thanks for the info on making your own grassmaster, but I have a Noch Grassmaster I got on ebay this year. I was asking because your grass looks great, but I haven't had the time to test mine yet. I should do a test before I actually try it out on a model though. Thanks
After seeing the job done by a couple of the flyswatter mods, I didn't think it was worth the effort. The one I did came off of a Youtube video. I too, waited for weeks until the static grass showed up. My buddy showed me a slick trick, after the glue has dried, put a paper towel over the nozzle of a small shop-vac and the unstuck pieces are about 98% recovered. Just make sure the paper towel doesn't get sucked into the vacuum. :erm: [{D]
