Originally posted by k9wrangler
Just an observation, that Rooster Pole would be one heavy son of a gun when yu got done with the shipment and wanted to use the disconnects for something else...
Pictured below is a push pole. A push pole is a hardwood pole between 8 to 12 feet long and 5 inches in diameter used between the 1870s and 1960s to push a freight car (on an adjacent track) onto or off a siding or other track. Placed between a locomotive and the freight car, the two ends of the pole would fit into receptacles called push pole pockets. You can see even they were hefty.
And then you have the rooster pole that was quite heavy as well. No such thing as OSHA back in those days.
And, that wooden dowel I have shown there is just a test pole with slots cut into it to hold the uncut coupler ends to test the fitting.
