  • And finally, the finale....Click image for larger version
Name:	all left_opt.jpg
Name:	left front_opt.jpg
Name:	all right_opt.jpg
    I knocked a hinge loose trying to open the door. I'll fix that later.
Name:	bad door_opt.jpg
Name:	right end_opt.jpg
    • Very natural and realistic, well done Fred!
      • Nice use of colors, Fred. Well done.
        • Very nice! You did a terrific job of modeling. I like it a lot.
          • Great scene!
            • Fred,
              WONDERFUL!!! The building and the entire scene look real!
              Nice job,
              • Thanks, Carl, George, Mike, Philip...... and Dave !! I see you found your way back.
                • After the mine my next project was to model an abandoned country store. There is no true prototype for the build although it will assume the name of a store that existed near here when I was growing up. It's long gone now. I didn't document the build as well as I should have because at that time I was beginning to think maybe the forum was terminal. So I concentrated on the build and not the presentation.
                  It is built on black foamcore, as are most of my builds. Starting with the main front wall.
Name:	black out_opt.jpg
                  The siding is a piece of naturally weathered veneer from a piece of plywood.
Name:	cut out_opt.jpg
                  I still wish I could update the thread title.
                  • Fred,
                    I should be ok now as long as I don't turn around too many times!
                    Good start on the store.
                    • A new Terrell build! Always good news.
                      I concur about documenting the build Fred......wasn't positive we were coming back .
                      • Fred,
                        Very good to see you starting a new build, I will be following. Since we no longer get emails on
                        postings to new or old builds I had to find this one sort of by accident!!
                        • Beautiful work on the mine. Looking forward to the new build!
                          • I'm looking forward to watching developments here. Did you a sketch first or simply lay it out on the foamcore?
                            • Thanks, Dave, Carl, Bob and Jerry!!
                              Mike, I never sketch first.
                              • New building and someone done kicked a hole in it
                                Nice start!
