Frank, I really admire your work and the way you describe the processes. I downloaded a couple of your posts regarding the way that you model rust for when I start to learn dry-brush techniques for weathering.
Just a little update on the radio control to date. I’ve connected all the pieces and nothing blew up. I flipped the power switch and the Phoenix unit started up the preinstalled GP-38 sound. Man it was loud, using the toggle switch I lowered the volume. I’ll get my transmitter on Wednesday and then I’ll program the A/W board to the frequency and loco number.
All the guts will be in the lead unit. I was going to split the load but that would require heavier wire from the battery unit to the front unit. By having it all in the lead unit I can make the wires shorter from the battery-switch-AirWire board. The battery will be on one side, the 2 PC Boards will be stacked on the other. The speaker will be in the trailing unit.
I’m working on the trail units wiring harness. I have a 10-pin and will be only be using 8 wires so I’ll have 2 for future options. I drilled holes in the rear pilots and the decks and fed the wires through. I printed strips of numbers from 1-9 and wrapped a section around the black wires of the trail unit. Then connected the plug and with an ohm meter I found the corresponding wire in the front unit. Then wrapped the same number to that wire. I didn’t do it for the red wire which is obvious which one that is.
After that I made the connections to the headlight, marker lights, speaker and motor.
I can’t believe I glued the partition to the wrong side of the line. Pictures never lie.
With the wires tucked into the non-speaker side I cut foam pieces and surrounded the speaker with them. The pictures don’t show but I also made a removable cover for the speaker compartment. OMG with the roof on it has great sound quality and more volume than I can stand. I turned the volume down some more.
Okay, the trail unit is finished.
I went on line to find the “OLD” AWD10SS A/W and Phoenix Big-Sound 96/97 information booklets. I couldn’t find an exact wiring diagram for the way I'm wiring the 2 boards so I came up with this one. The drawing was done in "Paint". I’m hoping it will work.
My aunt and uncle built a large house around the bungalow that they originally bought. That would have been in early 50's. Their house was 5 houses from Bertram's Island Amusement Park.
Diane's grandparents lived on the other side of the lake Sperry Springs.
Here’s a close up of the wiring harness between cabs. I zigzagged the connection so I’d have enough room to connect and disconnect the plug.
The inside of Cab A showing the battery pack, the stacked PCBs and the engineer’s cab. I’d like to get some more details in there so we’ll see.
And the plain speaker Cab B.
I had some Sundance Central decals left over from other build projects so I thought I’d add them here. I only had white so my numbers on the side will have to wait.
The engineer’s leaning out to get a better view.
I almost forgot to add the lights on shot. The marker lights in the front cab come on when the reverse lights are on.
THE ENDid="size3">
I hope you’ve enjoyed the thread as much as I have had building these little critters.
Carl, we’re getting there. We’ve been replacing about 100’ of rail where derailments were a huge problem. The heavy locomotives wore off the inner flange of the rail in the curves after 15 years of running.
Tim, maybe a short mixed consist.
Jerry thanks, Dave is the best. And he didn’t charge much either. I told him to deduct it from my pay.
