On building MoW cars
  • #31
    Looks good, Martin. You sure go through a lot of nbw's. I hope you're buying them at a bulk rate.
    • #32
      At one time I actually was buying parts from Grandt Line and Tichy in bulk amounts - 100 sprues at a time. Stuff that simply just gets used constantly doesn't need the individual bag packaging; just toss 100 sprues in quart baggies and I'm good.
      • #33
        :up: :up:
        • #34
          Originally posted by mwbpequod
          I'm not sure but I thought I had read somewhere that Photobucket recanted and is allowing pictures to be shared once again for free. There are probably stipulations but it would be nice to see all those old photos come back.
          • #35
            Got the other end together now....
            • #36
              Need a spool for the hose for the water from the tank on the car...
              • #37
                Every thread needs a spool.
                • #38
                  • #39
                    All done but a coat of matte and some weathering, but the assembly part is at the finish line now.
                    • #40
                      Looking good !!
                      • #41
                        Thanks, Fred.
                        This on is effectively done for now on the construction side of the project so it's getting set aside so I can get rolling on the next MoW car.....got to build while the fire is hot and Muse speaks.
                        • #42
                          Very nice, Martin. :up:
                          • #43
                            That is a fantastic looking piece of rolling stock!
                            • #44
                              Thanks!!!
                              I might get the next car started today if things stay quiet while the glue and plastering set on the layout,
                              • #45
                                . . . and while you have a fire lit under you.
