A major accomplishment as I've finished the Wild Horse Island causeway bridge that links the mainland with the island. I started with 3 Rix n-scale bridge kits and modified the pylons, added street light platforms and lights and also added a utility pipe along the front side.
The bridge gives me some depth as one of the things that I'm not thrilled about is the track basically running a circle along the edges of the benchwork. I did this so that I have max radius but it reduces the appearance of the track running through the scenery. Putting the bridge in front of the trestle over the marshland helps and I'll add some other details in between the track and the fascia as time goes on.
I still have to finish the decking but the rest is mostly done. The first pictures are prior to painting and adding the details and the last 2 are after the painting and addition of lights and pipe.
Expecting a delivery of from Scenery Express this week so that I can start some second layer scenery.
Dave. Looks excellent. The marshland looks so realistic, and rarely modelled.
I like the causeway bridge. I've been looking for some similar type sides for an elevated road to be part of my new layout, so those Rix items look ideal.
James, the lights are from Woodland Scenics (N scale) plug in system.
Scott, probably am influenced by the Jersey Shore; grew up in Philly and my parents live in Margate.
Yes Frank, the residents do complain about the Kablunk when they drive across
Received my scenery package in the mail and added some texture to the marshlands along with increasing the density of some of the marsh grass. The changes are subtile and not as evident in the pictures but with the naked eye there's less of an artificial look. First few pics show the terrain.
Also have finished the surface of the bridge, built up the embankment on the far side with Sculptimold and added the far side road. I cut a bit of the water surface away so that the bridge piers are more embedded in the ground which also levels the bridge with the adjacent roadway. I hid the lighting wiring and ran it through the benchwork with the intent to hook it up next week. Gonna call this done for a bit and at some point hope to find or make some N scale seagulls that I'd add.
Next week hope to connect all of the lamps I have already on the layout that were either disconnected during construction of the add-on section or by one of the cats. I also have to touch-up many of the areas that have plaster showing or that need a bit more TLC.
Dave, living in Tidewater Virginia and having made many trips over to the Delmarva Peninsula, I think you've done a great job of capturing the look of the area.
