The wooden decking has been put down onto the flatcar. The lead shot was glued using JB Weld epoxy. It may not be pretty but it does the job. All the wood was cut to length, and dipped into a brown leather dye mixture. Then placed in-between two pieces of glass to keep straight and flat. Once the wood stain was dried, the wood was glued onto the flatcar deck and sides using a thinned pliobond mixture. This was a tip from Dave Frary. Pliobond is an Industrial contact cement, and too thick for anything but the crudest work. Great for modeling if you take a used Testers liquid plastic cement bottle once it reaches 1/2 left in the bottle, and fill the rest with Pliobond, shake well and use for your model work, works great for Strathmore board work. The best part is the Testers bottle comes with a brush in the lid. As I use mine from the bottle, I just keep filling with testers and pliobond as needed. I like it better than Walthers Goo. Now moving right along!
Louis, the car is all decked out and your project is looking good. Would the brown oxen and yoke stand out more in photos after they get aboard if the deck and railing were more gray?
Good observation Bill at this present stain color, but once the wood chips/deadfall and straw are placed and glued onto the deck, like my horse car, and once everything is weathered over it should lighting up and tone down the flatcar leaving the Oxen standing out much more. Thanks for your comments and following along with this build. [:-cowboy] :up:
The flatcar post have been stained and installed/glued onto the flatcar deck. The top 4”x6” top railings have also been attached, and once glued, a section of top rail on both ends will be removed for a walkway for the workers. (See picture below). The stock Tyco Trucks will be replaced using Kadee 503 Arch Bar Freight Trucks for better performance. I was just going to replace the Tyco wheels with Intermountain wheelsets, and use Kadee #28 OR #27 Truck mounted coupler conversion set, but re-thought that idea real fast. It is just better overall replacing the trucks.
Nice work so far. Upon a quick observation..how are you planning on getting the oxen in and out of the car? By crane? I see you are providing a cut-out walkway, but I don't think they can walk up the stairs.
Maybe you can make one side a drop-down loading ramp, then add some chains on either end and some sort of locking rod or mechanism. Just a thought.
Boy, you seem to have a bunch of "Christmas" themed places around your area!
You're always finding neat things there...
Yes, I do find a lot of items Carl that can be used for modeling in those stores. These stores are open year round here. Thanks for posting your comments.
