O scale 1:48 Rural Auto Repair
  • O scale 1:48 Rural Auto Repair
    Xmas time is fast approaching so it’s time to make another railroad theme gift for my oldest son.
    This build is a diorama consisting of the auto repair garage and the owners house both sitting on a sloped piece of land.
    Both buildings will be weathered and in need of repair.
    Concept Sketch:
    Starting the build with the shingled and siding covered house. Designed the walls on Canson Illustration Art Board and cut out the profiles.
    I'm getting tired so I think I'll get ready for bed...More tomorrow. I sure hope I'm not boring you guys with another one of my builds.
    David, I don't think anyone will find your build boring.
    ed
      Yep, nothing boring about your builds!
        foamcore?
          Looks like another wonderful build starting !!!
            Christmas in October as we get to watch another build!
              Dave,
              I'll be watching too.
                I'll be following along as well.
                  Me too Dave.
                    Count me in to.
                      I'm in too Dave, your builds are an inspiration to all.
                        Looking forward to watching this play out.
                          Thanks Guys! Glad I haven't bored you too much and I appreciate you're following along.
                          Southpier...not using foam core. This time I'm using Canson Illustration Art Board. It's rigid and can be cut with an exacto. Holds it's shape without bowing and accepts balsa strips in the corners for gluing the corners. A little expensive...$20 for 10 sheets but use your Micheals or Hobby Lobby 40% off coupon and it works out to $1.20 for a 9"x12" sheet. I prefer it over foam board for smaller scales.
                          Since the house is weathered I decided to use paper siding similar to my 1:29 scale building methods.
                          The first step is to paint the siding. Started with a sheet of 8 1/2” x 11” gray construction paper.
                          Used a torn section from a sponge and dabbed Apple Barrel Antique White in a random pattern, allowing the gray paper to show through. The white will represent the peeling and vanishing white paint with the gray being the wood siding that is exposed to the elements. Allowed to dry for several hours.
                          Next step is to paint the shingle material siding. I’m going for a weathered brown look so I started with a sheet of light brown construction paper.
                          First step is to thin Folk art Raw Umber Acrylic (1 paint to 10 water) Apply randomly to paper with some areas light and some darker with two coats applied. Brush in one direction so the paint represents downward streaks when cutting the shingles.
                          Second step is to dry brush raw umber full strength in a few areas to accent the brown. (Heavy in some areas, streaks in other areas.)
                          Third step is to dry brush Craftsmart Graphite in streaks just enough to show and then add a few heavier areas.
                          When you’re satisfied with the coloring, set aside to dry.
                          Now it’s time to slit the paper. I used a Fiskar paper cutter and slit siding and shingles into 5/16” strips. The siding will be applied as is but the shingles need more work.
                          All of the strips of shingle material need to be cut to represent individual shingles. Take two or three pieces at a time and using a small pair of scissors cut approx. 3/16” to 1/4” slits with 1/8”, 3/16” and 1/4” spacing. Vary the spacing for a random shingle width pattern. Try not to cut through the shingle strip however if you do, they’re still usable.
                          The next step is to randomly notch some of the shingles. I use a toe nail clipper to make the notches. Small scissors will also work.
                          Sounds like a lot of work however, the whole process of stripping, cutting shingle widths and notching took 60 minutes for (24) 11” long strips.
                          Photo of scissors and nail clippers I used. The sharp point on the scissors is important to help you see what you are doing and provide a clean cut.
                          Next time I'll apply siding and shingles to the
                          walls.
                            Guff there has never been anything boring about your work. Always wonderful.
                            I did get a kick out of you saying 1/48 is a smaller scale! I know for you it is but those of us in HO and smaller, 1/48 is huge.
                            Lookin.g forward to more
                            TomO
                              Dave,
                              I'm subscribed. Will follow (and hopefully, learn) eagerly!
