Railbus Blues
Does anyone know the over the tread diameter of the Bachmann On30 Railbus driving wheels? I noticed that the wheelsets are available on the Bachmann repair parts site for a reasonable price.
The reason for the request is another blast from the past and not a particularly good one. The very first bash that I did in HO (before my interest in On30) was recently unearthed. The body was a variation of a Mack AC railbus that I made out of cardboard salvaged from cereal boxes. The body was reinforced with some thin wood slats cut from tongue depressors, which were cadged from the doctor's office. The body was built to fit around the power unit for an early HO single-truck streetcar.
These units, which just begged to be converted into some kind of rail vehicle, had only one driven axle that was geared to a typical five pole, open frame motor, mounted at an angle. However, the units had small wheels equipped with small diameter axles and this was a problem. As the only readily available larger diameter drive wheels were from Athearn Hi-F rubber band drive locos, homemade bushings were required to fit their larger diameter axle holes to the small axles on the unit.
Having coaxed the open frame motor back to life, I put the now ancient bash on the track and prodded it into operation. Much to my chagrin and my embarrassment, the old bash wobbles just as much as the new one does.
Dang it; before I shuck this mortal coil and go gentle into that good night, I want to bash a model railbus that does not wobble, even if it requires using factory made On30 railbus wheels, hence my interest in the Bachmann ones.
