Layout "DEAD RIVER LUMBER Co"
  • #16
    Hello everyone
    Despite the 38 ° in my attic and the local farmer spreading his manure, I finished the location of my engine house as suggested by a friend and I took the opportunity to coat the extruder around.
    • #17
      Great progress. Have you seen the work of RobertG on the Sierra West forum. Fellow Frenchman. Check him out, quite good. O scale.
      ed
      • #18
        Thank you very much, lots of things to remember, but I do not guarantee to be up to par
        • #19
          Today I made a rocky peak to justify the curvature of the track leading to the freight shed and coated the ascent leading to the bridge
          • #20
            I propose you the beginning of a small construction of an old west station to install it later on my layout. The frames are in samba of 9x9, the vertical and the blades are in balsa of 1mm, the frames of door and window in balsa of 2.
            You see that the two sides are not of the same width, it is normal since the station will be skewed and contiguous to the backdrop. I also added a small shed which I am finishing the roof and then I attack the one of the station
            Download Attachment: DSCI0034.JPG
            148.51 KB
            • #21
              This is where I am today
              • #22
                :up:
                • #23
                  I really like your use of balsa on this build. Looks like the grain is going in the right direction and should weather well.
                  Thanks for the tip on using those right angle picture frame vices!
                  Looking forward to seeing more of your progress.
                  Sully
                  • #24
                    Thank you Mike and Sully
                    some pictures but bland daylight colors that are darker in reality.
                    What do you think?
                    • #25
                      Wow, that's a superb build!
                      Are the doors and windows scratchbuilt?
                      • #26
                        Yes, thank you Dan
                        • #27
                          Hello everyone
                          After spending a good fortnight in the masonry, I resume my modeling activities.
                          Having bought ink cartridges (more expensive than my printer) I made signs for my station.
                          Here is what it gives
                          • #28
                            Nice scratch build. Looks great!
                            Seeing the roofing on the rear extend above the front reminds me that they did the same thing with some slate roofs. They called it a Combing Ridge.
                            It is a take off on the old Gillette maxim of "Give them the razor, and sell them the razor blades"
                            • #29
                              Nice looking structures, and wow on the turntable.
                              • #30
                                The new engine house location looks a lot better to me.
                                It's only make-believe
