Layout "DEAD RIVER LUMBER Co"
  • Layout "DEAD RIVER LUMBER Co"
    Hello everyone.
    It has been several months since I have posted because I was busy creating buildings for my layout. I am going to show them to you today.
    The layout consists of twelve modules which collapse (knockdown) and are easily moveable. Right now, I have three modules that lock together (?)
    I have much more work to do which I do by myself.
    I am looking forward to your comments on the modules I have completed so far.
    module1
    module 2
    module 3
    module 4
    module 5
    module 6
    module 7
    module 11
    module 12
    Very Nice work!
      I am looking forward to seeing future updates on your progress. What you have accomplished so far is well done.
        Thanks at you and thanks Railmus for your email
          So far quite good. Will look forward to following along. Thank you for sharing.
          ed
            Nice job, Jean-Gilles! Great bridge.
            But you shouldn't leave the blade of your knife in the open air when you don't use it...
              i follow the progress , nice work
                Thank you all for your comments.
                In order to clarify the photos I enclose a sketch of the layout of the tracks
                  Update;
                  Following a few comments from French modelers, I took up the position of the engine house.
                  I managed to fit it in line with the bridge, the only problem is that it will be riding on three modules.
                  On the other hand, it allows me to install three small feeder tracks, one in line with the bridge and the feeder. The turnout will be used for the logger tracks on the modules 8, 9, 10.
                  Two photos to illustrate the work.
                    Update of the day
                    I upgraded three sides of module 6 of the bridge in order to be able to join the rocks.
                    On module 7, I stuck the styrofoam and delineated the location of the tracks
                      Update of the morning
                      Bonding of sleepers, cut-outs of the rails (they are not fixed)
                        Awesome layout concept and great implementation. Well done!
                          Some progress made this day.
                          I found that my buildings were too close to the depot, so I started to make a corner which made it possible to remove them and to have space in front to be able to put accessories
                          I took advantage of it to redo the disposal of the depot.
                          You can see the future climb to bridge
                            As the weather leaves me a little time in relation to the garden, I took the opportunity to build a support for my bridge because the latter was in a diorama and included a wooden support on one side and the other a set in engraved stones.
                            To remain consistent, I made a wooden one almost identical to the first, but I am not satisfied with the rendering, I will arrange this when it is integrated with the decor.
                            Before treatment
                            After
                              Jean-Gilles,
                              The bridge abutment looks great! I also love your coaling station. Your buildings are looking wonderful, as well. I am looking forward to seeing it all come together.
