Micro Adjuster for Mini Table Saw
  • Micro Adjuster for Mini Table Saw
    I've been fooling around with a scatch build
    of a D&WRG caboose in 1/20.3 scale. This scale
    takes very large wood strips and I needed a way
    to micro adjust my fence to make fine cuts.
    I used my Balsawood strip cutter to make the
    adjustments on my fence by removing the blade and
    inserting a strait edge.
    id="size4">
    Hope this is useful.
    Is this an adjustable stop? Will it be used with a mitre gauge to cross cut strip wood to length?
    I saw a similar idea on a PBS wood working show this morning. I believe they had a mitre gauge with an extended
    Fence and a wood block clamped to it as a stop. They used a screw in the block to move the work piece in either direction with micro movements. I think the idea of using a threaded screw to make small adjustments is a good one. Another idea is to add or remove shims between the work piece and the stop block.
    I also noted that you placed your stop ahead of the saw blade. That is a good idea also, since it prevents jam ups or
    Potential kick backs
    Glad you posted this idea.
    Reg Barron
      I've looked at this a couple times and don't quite understand how it works. Could you show a piece of wood in place?
        I also don't "get it". I would use a much finer saw blade for stripwood. Those coarse teeth will hack the thin pieces to death.
        Dave Mason
        On30Kits.com
          Sorry about the confusion, I should
          have set the adjuster clamped to the
          table saw behind the fence. You could
          now creep up on the blade. As for the
          blade, I have a fine tooth blade for
          ripping strip but since I am building
          a large scale caboose I left that blade
          in.
          Hope this clears things up.
            Sorry for the confusion.
            I should have set the adjuster
            clamped to the table saw behind
            the fence so you could creep up
            on the blade. As for the blade,
            I do have a fine tooth blade for
            ripping thin strip, but I have
            been working on a large scale
            caboose, so the strips are
            much larger.
            Hope this helps.
