I have two more LV gons to assemble and decals for 2 or three more LV boxcars.
New W-and-N
I have created an entry in the "How To's" on my web page about building the helix on the new portion of the W&N:
https://wnbranch.com/how-tos/building-a-helix/
Dave Husman
Iron Men and wooden cars
Latest venture is my passenger staging area, Reading Outer Station.
I originally was just going to put a couple staging tracks near Birdsboro to hold passenger trains, but on the prototype the freight trains terminated at Birdsboro and the passenger trains went on into Reading, so I decided to move my passenger staging to the lower level. The station at Reading was a train shed on all three sides of a wye. I realized that I could use the trains shed to mimic the narrow opening of the staging area.
I laid the track, painted the city of Reading on the backdrop. I still needed to hide the transition between the backdrop and the physical layout. I decided that since there was a freight yard next to the leg of the wye that was used by the W&N Branch trains, I would put a string of freight cars to simulate the yard.
I photographed (several times to get the right angle) strings of freight cars. I then resized the pictures to about 60% of actual size, to create perspective, printed them, cut them out and glued them to the back drop.
The car pictures:
The scene with the "yard" in place and a mock up of the train shed, with the LED light I will use :
Next step is to start working on building the ornate portal of the train shed:
Dave Husman
Looks great Dave. They sure knew how to build fancy structures back then. I look forward to seeing how you handle that.
That Helix is really impressive.
:up:
I started working on Birdsboro, the northern terminus of my layout, in November, with the goal of laying 18-20 switches by the end of December.
Here is a picture of the yard at the end of November, wit the switch templates being laid out to finalize the track plan.
By Dec 1 I had all the ties in place.
Christmas Day I finished laying the track I needed to make Birdsboro operational and to allow the temporary staging to be removed. The work included 3 #6 switches, 3 curved switches, 1 #5 3way switch, 16 #5 switches, all in code 70. 16 ft of main and wye in code 70. 4 staging tracks (32 ft) in code 70 (24 ft handlaid) and 22 ft of yard track handlaid in code 55.
Other useless statistics, about 3000 track ties, 750 switch ties, 4200 spikes.
Dave Husman
Dave, how do you drive the spikes? Do you drill pilot holes, or just push them into the ties? (I can't say I've had much luck just pushing the small spikes into wood ties without a pilot hole...)
I use what I call a "pick". I take a 3/4" long piece of 1/4" dowel and drill a 1/16" hole i down the center. A 1" long piece of 1/16" dia brass tube is super glued in the hole. I get a #8 or 9 embroidery needle and solder it into the brass tube. I then use that to punch a hole in the tie and drive the spike into the hole. The time you lose punching the hole you gain in being able to spike 95% of the spikes on the first try.
I used "regular" needle nose pliers when I drove ME small spikes and bought Micro Mark spike driving pliers also. They worked great with the small spikes. When I went to ME Micro spikes, I bought a pair of the Micro Mark fine nose pliers and found they were easier for me to use. YMMV.
Dave Husman
